Thread: stiff brake pedal and limp mode
  1. Unhappy stiff brake pedal and limp mode
    hi guys a quick one not sure on how serious the problem is but seems bad
    i started my car other day like normal and low and behold the brake pedal was rock hard stiff as if id pumped the pedal with no keys in.
    i decided to take it out and see if it sort itself out and found what my non-expert feel was the car had gone into limp mode..no power etc
    now i know my front brake warning light has been beeping at me for a few weeks and gatherd that its them that need replacing pronto now
    could this be the reason the brake pedal is stiff and cars in limp mode?
    help greatly appreciated
    thanks in advanced
    Sam
    2003 audi a4 1.9tdi (130) quatrro sport
  2. Re: stiff brake pedal and limp mode
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    It may be your vacuum pump has failed and the valves required for Turbo etc are not recieving vacuum,so going into limp mode.
  3. Re: stiff brake pedal and limp mode
    Nov 2008
    Split cracked vac pipes too.......
  4. Re: stiff brake pedal and limp mode
    May 2008
    You need to get the car read for fault codes, either someone with vag com or a garage. Only then can you attept to determine the cause of limp mode. More than likely it will be overboost or underboost code. When you get the code post it up and you'll get a better chance of what can be eliminated.
    Unlikely to be brakes related tho. Get a front wheel off and check how much pad you have on the inner pad, you'll be able to gauge how long you have left on them, but aim to replace soon.
    Mauritius Blue TDI Sport GmbH Avant | 35% Tint | Custom Remap by Awesome GTI - 180BHP - 450NM - Gone! | RS6's | Goodyear Eagle F1 Asymmetrics | RS 4 RARB | RS 4 Pedals | B7 Black Optic CatBack Twin Exhaust | HIDS
  1. From a very fed up owner.
    By pistons in forum Fabia
    Last Post: 31-05-2011, 05:19 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. newbie with warning lights please help
    By tim7900 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-09-2007, 11:02 PM
  4. Can anyone help me???
    By GreatGig in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-09-2007, 08:38 PM
  5. What Brakes
    By Tonka73 in forum Passat - Archive Topics
    Last Post: 08-01-2007, 01:11 PM
