Thread: Retrofit auto lights function
  1. Retrofit auto lights function
    Aug 2009
    Norway
    Anyone retrofitted the auto lights function?
    I have adaptive bi-xenons and DRL lights (which turns on automatically with the ignition), but when it gets dark I have to turn the knob over manually (as well as when I stop the car I get annoyed by the beeping), and even more annoying, I have to turn it on and off in every tunnel around if I want to see the speed I'm going at, which can be quite annoying here in Norway with tunnels all over the place.
    Is it just a question of replacing the light switch, adding a light sensor somewhere and do some coding, or is it more complicated?
    Audi B7 A4 Avant 2.0TFSIQ aut (241hp, sports susp., valc. leath. sports seats, MF sports steer, navi plus, BOSE, BT, PDC, dyn. bi-xenon, 18" MOMO GT-R)
    BMW 118d (185hp, alu trim, sports int, rain s., navi, MF steer., BT, PDC, 17" M, dual clim., M aerodyn)
    Volvo XC90 (bull bar, side steps, widebody/wheel arch., dual AC, MF steer, 7S, el. leather seats, navi, rain s., phone, prem. aud., bi-xen.+xen. driv. lamps, Webasto, PDC)
  2. Re: Retrofit auto lights function
    Jun 2008
    Marmitehampton
    There are guides around, but you need the auto dimming mirror as well as it has the light sensor in it. Unfortunately this mirror has a different boss connection to the windscreen so you would need to change the windscreen as well...
    Not cheap... I was going to try it but decided not to. I have the switch if you want to buy it off me. PM me.
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  3. Re: Retrofit auto lights function
    Dec 2006
    One thing you can do is set up the cluster via VAG-COM so the needles are always on, or the full cluster panel is always on.
    As you have your headlights on all the time, I would go for the full cluster..
    if you need to codes, let me know.
    Rick
  4. Re: Retrofit auto lights function
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by Flakmunky View Post
    I need a switch, if grr decides not to have it.
    A4 2.5 tdi QS (mapped)
  5. Re: Retrofit auto lights function
    Jun 2008
    Marmitehampton
    Kite, PM sent...
  6. Re: Retrofit auto lights function
    20 Post(s)
    Back at yer...........
  7. Re: Retrofit auto lights function
    Aug 2009
    Norway
    Quote Originally Posted by RickT View Post
    Rick
    Interesting!
    I'm new to VAG so I haven't gotten VAG-COM yet. I do however have a lot of stuff for diagnosing and coding BMWs. Maybe the OBDII cable I use with the BMW interface can be used for VAG-COM directly to the serial port on the laptop..?
    Can the xenons be coded to be always on as well?
  1. Fog lights on with auto lights setting?!
    By Edjog in forum Golf MK6 - 2009 - 2013
    Last Post: 03-11-2009, 12:53 AM
  2. Auto Lights oddity
    By MFGF in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-09-2009, 12:13 PM
  3. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
