Thread: gearbox isolator switch??????
Results 1 to 10 of 10
  1. gearbox isolator switch??????
    May 2008
    Cork,Ireland.
    I have a 2000 allroad 2.7t with tiptronic gearbox,after driving to work this morning I needed to move the car but the car failed to start.After numerous attempts I eventually got it started by slamming the gear selector up and down through the gears and eventually it started,am I right in thinking there is a safety switch to stop the car being started in D,R or gears 2,3,4 and that this could be faulty?
    2000 Audi allroad 2.7t bi-turbo quattro
    1987 Audi Coupe quattro
  2. Re: gearbox isolator switch??????
    The starter inhibitor and reversing light relay receives information from the multi-function switch
  3. Re: gearbox isolator switch??????
    May 2007
    the switch in question stops the engine turning over. If it was spining then that's not the fault.
  4. Re: gearbox isolator switch??????
    May 2008
    Cork,Ireland.
    The engine does not turn over.........where is the inhibitor switch located?How could I recognise it?
  5. Re: gearbox isolator switch??????
    Since the engine started after you juggled with the gear selector i'am inclined to think the fault is with the multi-function switch.A fault code read might verify this.I beleive the relay is in position 4 on the relay-box
  6. Re: gearbox isolator switch??????
    The multi function switch is on the side of the gearbox. Regards Peter
  7. Re: gearbox isolator switch??????
    May 2008
    Cork,Ireland.
    I failed to get the car started this morning....
    I am new to Vag com but have just scanned the car VCDS Version: Release 908.0
    Data version: 20090911
    Friday,16,October,2009,19:03:55:59214
    Chassis Type: 4B - Audi A6 C5
    Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
    76 77
    VIN: WAUZZZ4BZ1N001702
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Part No: 4Z7 907 551 C
    Component: 2.7l V6/5VT G 0003
    Coding: 10752
    Shop #: WSC 66565
    WAUZZZ4BZ1N001702 AUZ7Z0Y1405303
    1 Fault Found:
    16955 - Brake Switch (F): Implausible Signal
    P0571 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 4Z7 927 156
    Component: AG5 01V 2.7l5VT RdW 3535
    Coding: 00001
    Shop #: WSC 00000
    No fault code found.
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 4Z7 907 389
    Component: ABS/ESP allrad D36
    Coding: 06397
    Shop #: WSC 02325
    Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
    Part No: 4B0 820 043 L
    Component: A6-Klimavollautomat D64
    Coding: 00061
    Shop #: WSC 00000
    2 Faults Found:
    01809 - Actuating Motor for Temperature Flap; Left (V158)
    41-10 - Blocked or No Voltage - Intermittent
    01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
    30-10 - Open or Short to Plus - Intermittent
    Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
    Part No: 4Z7 959 655
    Component: Airbag Front+Seite 1000
    Coding: 01106
    Shop #: WSC 02325
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4Z7 920 980
    Component: C5-KOMBIINSTR. VDO D06
    Coding: 00464
    Shop #: WSC 00518
    1 Fault Found:
    01310 - Level Control System Control Module (J197)
    49-10 - No Communications - Intermittent
    Address 34: Level Control Labels: 4Z7-907-553.lbl
    Part No: 4Z7 907 553 A
    Component: - 2C1A1 X030
    Coding: 25500
    Shop #: WSC 00518
    Address 35: Centr. Locks Labels: 4B0-962-258.lbl
    Part No: 4B0 962 258 H
    Component: Central Lock/Alarm D33
    Coding: 04846
    Shop #: WSC 00000
    Address 36: Seat Mem. Drvr Labels: None
    Part No: 4B0 959 760 A
    Component: Sitzmemory D05
    Address 37: Navigation Labels: Redir Fail!
    Part No: 4B0 035 192 F
    Component: Navigation BNO 0001
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00002
    Shop #: WSC 00000
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D03
    Coding: 00030
    Shop #: WSC 00000
    Address 56: Radio Labels: Redir Fail!
    Component: Radio BNO 0001
    Coding: 00017
    Shop #: WSC 00000
    Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
    Part No: 8E0 919 283
    Component: Parkingsyst. A6 RDW D01
    Coding: 01186
    Shop #: WSC 00000
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    returned the following faults..
    The brake switch fault is new as It wasn't there last night when I scanned the car,I have just checked the brake lights and they are working!
  8. Re: gearbox isolator switch??????
    The fault is pre-set when the ignition is switched on and will be erased when the brake pedal is pressed once, provided that brake light switch -F- is OK You can check the multfunction switch in measured block values address 02 group 004 and display zone 2 and 3 you may need a chart which i can not post so i need your e-mail addreww
  9. Re: gearbox isolator switch??????
    May 2008
    Cork,Ireland.
    pm sent.....
  10. Re: gearbox isolator switch??????
    May 2008
    Cork,Ireland.
    Update:
    The problem turned out to be the ignition switch in the end,thanks to all who replied!
  1. VW Sharan VR6 (99) Auto gearbox problem
    By bluemozzer in forum Touran - Sharan - Caravelle
    Last Post: 01-01-2013, 11:53 AM
  2. Help! A4 gearbox nightmare!
    By Patsy666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2008, 02:48 PM
  3. ** Manual Gearbox Problem 93 Polo CL Coupe **
    By VWPeoplePower in forum Polo - Derby - Lupo - Fox
    Last Post: 24-04-2008, 12:09 PM
  4. Help! A4 multitronic gearbox problems!
    Last Post: 18-04-2008, 10:18 PM
  5. Replies: 0
    Last Post: 22-12-2007, 03:29 PM
