Thread: Emission garage warning light
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Emission garage warning light
    Aug 2009
    Maidstone UK
    The emission warning light came on today, & has stayed on. my 1.9S Passat I contacted my local VW garage, but they can't look at it till Monday next week. My dilemma is that I'm due to make a look 600 mile trip before that, the guy in the garage said it should still be ok to drive as long as the light stays solid & does not flash. Can someone please advise, should I postpone the trip?
  2. Re: Emission garage warning light
    Norfolk
    Lots of garages can do a quick scan for fault codes. If your worried, why not ring round to find one that can scan it now. Then you will have an idea why the light is on.
  3. Re: Emission garage warning light
    Oct 2009
    Essex
    Have you just been driving local journeys recently? Could be the diesel particulate filter blocked!
    There's a fine line between genius and insanity!
  4. Re: Emission garage warning light
    Aug 2009
    Maidstone UK
    Not really, I use it mainly for motorway driving, but as the car only had 15K on the clock (07 plate) when I bought it a couple of months ago, its probably worth checking out.
  5. Re: Emission garage warning light
    Dec 2008
    Sale
    does the 1.9 have a DPF?? I didn't think so
  6. Re: Emission garage warning light
    Sep 2009
    England
    Nope - It doesn't have DPF fitted
  7. Re: Emission garage warning light
    Oct 2009
    Essex
    My apologies, mistaken for a later model!
  8. Re: Emission garage warning light
    May 2009
    Aylesbury Bucks
    Hi!I had same problem with mine Passat 2.0 tdi after VW garage replaced tandem pump,they have to disconnect air flow sensor from the air filter hose.after they put everything together they did not connected it properly.so it was loose!check if is loose and if it is just press sensor and problem should solved itself if is not that so probably is one of the lambda sensors.Good Luck
  9. Re: Emission garage warning light
    Jan 2010
    Lisburn, United Kingdom
    Digging up an old thread. My brother went out in my car this morning and te same light came on. Recently had the clutch and flywheel replaced so mechanic could have knocked the cable loose. Conrad83, do you know where the air flow sensor is under the bonnet?
  10. Re: Emission garage warning light
    DSG4ME Guest
    This used to happen on the Skoda's with the 1.9, if the car still ran fine, 99% of the time it was the coolant temp sensor causing it, if it has no gut's, it should be a simple pipe that's come off/got a hole in it, hth.
  1. Emission Control System Warning Light (A4 Avant 1.9TDi 130PS AVF Multitronic)
    By trlaing in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-06-2008, 10:59 PM
  2. Pads Warning light will not go off
    By Shaz12 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2008, 10:42 AM
  3. Polo emission warning light
    By davidpboden in forum Polo - Derby - Lupo - Fox
    Last Post: 26-01-2008, 10:13 PM
  4. 1.9 tdi turbo cut out/ emission warning light
    By warwick01045 in forum Archive posts
    Last Post: 03-06-2007, 11:12 AM
  5. warning light
    By wednesday13 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-03-2007, 09:38 AM
