Thread: Stripped the passat, now airbag light won't go off?
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Question Stripped the passat, now airbag light won't go off?
    Oct 2009
    Uk, chorley
    stripped my passat
    took doors,
    bonnet
    boot
    bumpers etc off for colour change!
    Now it's built up the airbag light won't go off
    any one no what's happened?
    Should I have stripped it a certain way?
    Please need help asap, thanks
  2. Re: Stripped the passat, now airbag light won't go off?
    Scunthorpe
    I'm intrigued. Why?
    It's possible that an airbag was disconnected and the ignition turned on - that'll screw it up if you're, say, changing the stereo so in this case, it could be the same. It's a dealer (or VAGCOM) reset I believe though...
  3. Re: Stripped the passat, now airbag light won't go off?
    Oct 2009
    Essex
    Quote Originally Posted by Killer passat View Post
    stripped my passat
    took doors,
    bonnet
    boot
    Just a reset needed no big deal, doesn't even have to be main dealer or Vag-Com, most competent mechanics these days own good scanners such as Snap-On etc. Probaly charge you about 25 quid for a reset!
    There's a fine line between genius and insanity!
  4. Re: Stripped the passat, now airbag light won't go off?
    Oct 2009
    Uk, chorley
    No DEFINATLY not, no airbags was disconnected,
    All windows come out, (gone back in today)
    doors come off (so got unplugged from b post and a post)
    bonnet come off
    bumpers
    and boot lid and loom removed from inside it,
    the only two things that need refitting are boot lid, bonnet and bumpers
    why would the airbag light even come on if I didn't disconnect or go anywhere near them?
    I'm confused
    and thanks for the promt replys
    will follow with pics of the car
  5. Re: Stripped the passat, now airbag light won't go off?
    Jul 2008
    Coventry
    it will come on if the ignition was turned on with any part of the airbag system disconnected, i'm guessing here but maybe a collision sensor in the bumper or door?
  6. Re: Stripped the passat, now airbag light won't go off?
    Oct 2009
    Uk, chorley
    Does any one no if the doors,? Boot or bumpers have collision sensors in!?
    I'm a few days of fully completion and it's just really worrying me now
    any help would be great
    and thnks for you quick replys
  7. Re: Stripped the passat, now airbag light won't go off?
    Jul 2008
    Coventry
    even if everything is now reconnected and working ok the light will stay on until it is reset by someone with diagnostic equipment - your dealer or someone with vagcom or a similar fault code scanner.
    so you need to get someone to reset it and then start the car again, if it comes on again then you do have a problem but if it stays off after you reset it then all is now well.
  8. Re: Stripped the passat, now airbag light won't go off?
    Oct 2009
    Uk, chorley
    ahh how much dealer charge for that?
  9. Re: Stripped the passat, now airbag light won't go off?
    Scunthorpe
    Depends on the dealer really, but I reckon £20-30 should cover it - if it's a simple error. As stated above.
    What are you doing to your Passat anyway?
  10. Re: Stripped the passat, now airbag light won't go off?
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by james_tiger_woo View Post
    At this rate j_t_w won't get any sleep tonight
    1996 Laguna 2.2D
    1977 MGB roadster
  1. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. Please Help A3 Sportsback '09 DPF Warning Light!
    By Foggie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-10-2009, 12:48 PM
  4. 1996 a4 airbag light reset
    By pogues in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-08-2008, 05:46 PM
  5. Golf Mk5 Airbag Light / Module
    By scooby-golf in forum Golf MK5 - 2004 - 2009
    Last Post: 13-11-2007, 10:57 PM
