Thread: Corrado 2.0 16v Running Problems
  1. Corrado 2.0 16v Running Problems
    Oct 2009
    Romsey England
    Hi all,
    I am the owner of a K registered 2.0 16v Corrado which recently has suffered from poor running problems.
    The car will start however I cannot get the engine to exceed 1500rpm. it then dies and hunts very badly. The problem can be resolved by leaving the car to warm up and noticing a change in the engine tickover. After that it is driveable but very sluggish.
    I have replaced the air flow meter, water temp sensor and checked for any vacumn leaks in the pipes but to no avail.
    Does anyone have have ideas on the problem? Have owned this great car for over 15 years now so anxious to keep on enjoying.
  2. Re: Corrado 2.0 16v Running Problems
    Oct 2009
    Lancashire, England
    I'm not familiar with the valver, howwever have you asked on the corrado forum? www.the-corrado.net There's a wealth of Corrado specific knowledge on there
  3. Re: Corrado 2.0 16v Running Problems
    Gwent
    I had a passat with the 9A engine. The water temp sender sheared off when I tried to remove it. The replacement was probably not correct and this caused poor starting and cold running, - Strangely it would start and run ok if the throttle pedal was not touched.
    VW were unable to sell me the correct temp sender.
    A lambda sensor problem could account for the sluggishness when warm. Probably would be a good idea to change it anyway if it has not been done?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  3. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  4. 1997 Golf GTI 2.0 16v misfire
    By Tommyl1968 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-07-2007, 02:33 AM
  5. RUNNING PROBLEMS
    By josianlib in forum Archive posts
    Last Post: 13-01-2005, 06:00 PM
