Thread: Audi A3 water leak - not coolant
  1. Audi A3 water leak - not coolant
    Oct 2009
    Guernsey
    Hi Guys,
    Im a newbee to the forum and a newbee to Audi. bought a 04 Audi A3 2.0 FSI on Weds, amazed at how good a quality this machine is!! but checking under the car today and last night, I have noticed there is a leak. However I dont think this is engine coolant as the temp gauge is fine and the coolant level is consistant.
    the leak is occuring from under neath a panel which is located directly behind the drivers side front wheel. from the underside of the car, it is pretty much directly under where the driver sits but located more towards the center of the car rather than by the skirts. (which makes me think its air con rather than engine coolant)
    if anyone has any ideas on what this could be underneath this plastic/grooved panel then please let me know. my first impressions are possible air con system? but would like to know if this is correct and also if anyone has any experience with this or a simlar problem.
    Thanks in advance to all you guys.
  2. Re: Audi A3 water leak - not coolant
    It is the AC,turn the AC off and you will see it stops dripping
  3. Re: Audi A3 water leak - not coolant
    Oct 2009
    Guernsey
    ok thanks for the info. so is this a problem then or just one of those things so to speak? its just i was given a 3month parts and labour warranty with it and if i cna get it sorted for free then i'd like to.
    thanks for your speedy response
  4. Re: Audi A3 water leak - not coolant
    No problem,just one of those things as you say
  5. Re: Audi A3 water leak - not coolant
    Southern County Softy
    20 Post(s)
    Aircon codense's the moisture from the air and the drip is the result.
    A4 2.5 tdi QS (mapped)
  6. Re: Audi A3 water leak - not coolant
    Oct 2009
    Guernsey
    right now i get it. i was just suprised at how much was leaking. after having it parked for around 2 hours after a 1 hour drive with the aircon on, the patch of water it left was quite considerable (I'd say around 30 cm's long.) it just seems alot?!
    maybe im just being a little anxious as its the first car i have owned with aircon!
  1. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  2. a4 multitronic problem
    By a4god2ulot in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2007, 02:52 PM
  3. New Audi A3 Will Be Free To Charge Into London
    Last Post: 20-08-2007, 08:55 PM
  4. How does the Quattro system work?
  5. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
