Thread: Touran fsi NOx sensor
Results 1 to 10 of 14
  1. Touran fsi NOx sensor
    May 2009
    wrexham
    Hi ive got a touran in with codes 17443 p1035 and 17441 p1033 engine BAG relating to NOx sensor problem. there appears to be three sensors two lamda sensors and a pencil shaped sensor in the cat i guessed this one was the NOx sensor, but when i ordered it what came looked like a lamda sensor with a control unit £300 quids worth, can anyone tell me if this the NOx sensor
  2. Re: Touran fsi NOx sensor
    130 Post(s)
    1972 Post(s)
    What is the part number of the part you have received, 03C 907 807 D?
  3. Re: Touran fsi NOx sensor
    May 2009
    wrexham
    Hi crasher
    yes thats the number they sent me
  4. Re: Touran fsi NOx sensor
    130 Post(s)
    1972 Post(s)
    That is the post cat NOX sensor.
  5. Re: Touran fsi NOx sensor
    Aug 2009
    Wiltshire
    What does the post cat NOx sensor do?
    I have the same code come up on my Golf 2.0 FSI BLX.
  6. Re: Touran fsi NOx sensor
    130 Post(s)
    1972 Post(s)
  7. Re: Touran fsi NOx sensor
    May 2007
    17 Post(s)
    There is a known issue with these sensors. I can't remember the details off hand, but sensors built before a certain date were to be replaced. Later ones were OK but the software in the engine control unit was to be updated. The build date is on the control box. It's a number something like 30/04. I'll check my notes when I go back to work and post the details.
    Jim.
  8. Re: Touran fsi NOx sensor
    Aug 2009
    Wiltshire
    Thanks,the car seems to run OK,I just got VCDS Lead and I plug it in to my golf to activated it and one fault code came up .Nox sensor
  9. Re: Touran fsi NOx sensor
    Dec 2008
    I read in another forum that when changing the NOX sensor (Touran 1.6 FSI 2004 ) a software update is needed. What happen if one only mounts the new sensor without updating the software ?
  10. Re: Touran fsi NOx sensor
    Oct 2010
    Inverness
    Is your error permanent?
    Do you really need to replace the sensor?
    I've had this error twice now on my 2004 Touran 1.6 FSI Both times I just reset the error.
    It's just passed it's MOT, emissions are fine.
    So if it only flags this error once in a blue moon, I will live with it rather than spend hundreds messing about with new sensors.
  1. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  4. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
  5. Audi Injects Even More FSI Efficiency Into 2007 Range
    Last Post: 04-12-2006, 08:06 PM
