Thread: mk 4 golf engine keeps cutting out!
  1. mk 4 golf engine keeps cutting out!
    Sep 2009
    carrick ireland
    hey, i have a 99 mk4 golf. For a few weeks now i've had difficulty starting the car. A few days ago the car started to cut out as i slowed down-say at traffic lights etc. Yesterday this happened at least ten times in the space of 15 minutes. I won't drive it as it's too dangerous. just went out to check it now, it will start up but cut out while ticking over.Any ideas?
    I think it might be an air/ fuel problem but i'm a total novice!!
  2. Re: mk 4 golf engine keeps cutting out!
    Apr 2009
    Quote Originally Posted by john78 View Post
    1.4/1.6 Engine?
    Do you know the engine code?
    Seems there are several topics regarding this fault and no definitive solution has been created. I have a 1.4 (AHW) engine suffering from the same thing, however mine only happens perhaps one a month.
    When the car cuts out, there are no lights on the dash? As if the car hasn't cut out atall. This basically means that the ECU hasn't realised the car has died atall, which is rather worrying. If there are lights on the dash, then this could point to a throttle body issue, in which case it may need cleaning out, and re-adapting.
    My Topic Of The Same Fault, with a few good responses:
    https://www.vwaudiforum.co.uk/forum/s...ght=post+fault
  3. Re: mk 4 golf engine keeps cutting out!
    131 Post(s)
    1973 Post(s)
    Use the force Luke, use the Force! These cars have sophisticated on board diagnostics that log fault codes with almost all problems, don't guess, get it read for codes!!!!
  4. Re: mk 4 golf engine keeps cutting out!
    Sep 2009
    carrick ireland
    Thanks for the reply imcammers and the other lad. It's a 1.4 16v. When my car cuts out, the lights and everything go, so i'd say we might have a different cause to out problem. I think i'll bring it to a non vw garage and have it put through a computer. Hopefully i won't be **** raped!
  5. Re: mk 4 golf engine keeps cutting out!
    131 Post(s)
    1973 Post(s)
    Lad, LAD! Cheeky little oik, I am a middle aged man of 45!!!!!
  6. Re: mk 4 golf engine keeps cutting out!
    Jan 2010
    Grimsby
    I have the same problem with my 1.4, but I've just had mine go in for its MOT, and apart from the usual things that can be fixed (tyres etc..) they are having troubles with the emissions, saying the results are way out, even after i had it serviced.
    If I find out the problem within the next few days I'll let you guys know (I just hope its not too costly, student and all that!)
  1. The fastest-accelerating volkswagen yet: The new golf r
    Last Post: 15-09-2009, 08:29 PM
  2. Replies: 0
    Last Post: 15-08-2009, 07:48 PM
  3. More economical, more practical: The new golf plus bluemotion:
  4. Golf TDI 90/110bhp engine query
    By william200mph in forum Golf MK3 - 1993 - 1999
    Last Post: 04-04-2008, 02:18 PM
