Thread: Radiator fan fuse location
  1. Radiator fan fuse location
    Mar 2007
    Does anyone know where the fuse is for the radiator,the manual says to check it as the car is overheating but does not say where it is.Any ideas would be great thanks to all of you. It is a vw passat tdi 130 .02 plate.
    Mar 2007
    south wales
    it should be in the main fuse box,its 20 amp
    Oct 2005
    Lutterworth
    Quote Originally Posted by Dacabbie View Post
    The electric fan should run all the time the climate is on.
    At this time of the year in the UK, overheating will not be caused by the e-fan not running, remember there is a viscous fan as well.
    If it is not running then the most likely problem is with the fan itself.
    Test by reading its motor resistance from the connector panel near the PS reservoir. The connector with the two thickest wires is the one you want.
    If that is ok then the next most likely candidate is the resistor plate that controls the speed of the fan. Test by disconnecting the radiator thermal switch, lower ns of the rad, and short each pair of wires in turn, 1-4 and 2-3. One pair runs the fan at full speed and the other runs at slow speed. If it only does full speed then the r-plate is duff.
    The fuses for the fan are under the dash, above the driver's feet, and almost inaccessible :-(
    You need to drop the lower dash off to see them: two screws on the end near the main fuse panel and two hidden in the cubby holes.
    As I recall there is a 5 amp fuse for the relays and 40 amp for the fan itself.
    You can tell I have just had problems with mine can't you
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Mar 2007
    Thanks for that ,when my hubby gets up he will go and have a go I expect,so fed up with car going wrong now.He is a cabbie and it always plays up on his busy nights,he needs a mobile mechanic livving in his home.Cheers and have a good day.
  5. RE fuses for fan
    Mar 2007
    I am in the process of doing as suggested but am wondering if the fact that I have an oil leak coming from the oil filter area has anything to do with it,anymore suggestions please (to stop the leak) So need to get this problem sorted .Thanks.
  1. fuse location for radiator fan on mk4 golf
    By elliotta44 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-06-2007, 07:36 AM
  2. fuse location for petrol locking cap golf mk4
    By stejuk in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2007, 07:09 PM
  3. 80 Td Radiator
    By Shearer85 in forum 80 - 90
    Last Post: 29-05-2007, 01:44 PM
  4. Radiator
    By goonda in forum Passat - Archive Topics
    Last Post: 18-04-2007, 11:03 PM
  5. New Radiator
    By humberdale in forum Passat - Archive Topics
    Last Post: 21-11-2006, 08:44 PM
