Thread: t5 2005 model 130bhp lwb loss of power at 80mph
Results 1 to 10 of 11
  1. Smile t5 loss of power at 80mph
    Aug 2009
    leicester uk
    hi guys im new at this and really need some help please!!!
    ive just started having problems when im on the motorway and going at about 80mph and then trying to overtake the van just loses power and goes down to 60mph and then wont pick up speed till i switcg it off and then switch on again..
    ive taken it to my mechanic who works at vw and he sed it was overboosting and so thought to change the thrust sensor which cost about £42 from vw and then the problwem went for about 2000miles and jst to my luck has just started again and i wanna know wat can i do to resolve it ... will i need to chancge the maf sensor and clean the egr valave as ive read somewhere that changing the turbo doesnt help at all???
    all help welcome asap as im a taxi driver and always doing the airport runs....
  2. Re: t5 2005 model 130bhp lwb loss of power at 80mph
    Aug 2009
    uk
    the red and yellow wire running from the egr has a short follow it back over engine and you will see it is fray
  3. Re: t5 2005 model 130bhp lwb loss of power at 80mph
    Aug 2009
    leicester uk
    thanks i will do that but what do i need to solve this issue
  4. Re: t5 2005 model 130bhp lwb loss of power at 80mph
    Aug 2009
    uk
    connect the wire back up and remove from limp
  5. Re: t5 2005 model 130bhp lwb loss of power at 80mph
    Aug 2009
    leicester uk
    thanks mate i will do this tommorrow and then let u know
  6. Re: t5 2005 model 130bhp lwb loss of power at 80mph
    Apr 2010
    Bristol
    ~Did you get any resolution to this issue?
    I've got the same problem with my 130 T32.
  7. Re: t5 2005 model 130bhp lwb loss of power at 80mph
    Apr 2010
    Corsham
    I had the same frustrating problem over the past six months. In my case the vehicle went into limp mode after I had done a long run of 100 miles or more. It never happened during local running about.
    Because of it's intermittancy the fault was hard to trace, and the ECU showed no record of a fault on diagnostic test. Finally my local dealer came out on an extended road test with his diagnostic equipment. This showed the turbo was "over-boosting". Apparantly because of the over-boosting, the pressure was such that the ECU put the engine into limp mode to protect the engine. When you turn off the ending for a couple of seconds it resets the ECU and off you go again until the boost pressure again becomes excessively high.
    I am told, and I only have the dealer's know-how to go by, there are variable vanes in the turbo, and when these stick you get the overboost problem. The turbo was replaced and I have had no further trouble.
    Forgive my layman's explanation, but I am not conversant with these modern engines !.
    Hope this helps. Anton Prole.
  8. Re: t5 2005 model 130bhp lwb loss of power at 80mph
    Jul 2007
    Cheshire, or my A6
    You may also get overboost conditions if you have any split hoses... my T5 had a split intercooler pipe which caused exactly the same problem.
  9. Re: t5 2005 model 130bhp lwb loss of power at 80mph
    Apr 2010
    Corsham
    Dear Paul,
    In my case they checked the pipes - all were ok, but it's certainly the thing to check first before blowing a fortune on a turbo.
    Best wishes, Anton.
  10. Smile Re: t5 2005 model 130bhp lwb loss of power at 80mph
    Aug 2009
    uk
    had the same trouble with 3 in 10 months never had the problem with the 1900cc deffinatly a better van hands down
  1. power loss etc gti 8v, confused!
    By johnny80 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-03-2008, 02:32 PM
  2. Sudden Loss of Power
    By shaz75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-03-2008, 08:57 PM
  3. TDI Sudden Power Loss! Later higher MPG?
    By TDI-3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 05:32 PM
  4. Power Loss
    By decky in forum Toledo
    Last Post: 19-02-2008, 07:38 PM
  5. Golf TDI Power Loss
    By donnytella in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-07-2007, 10:31 AM
