Thread: Polo 1.4 twist Cam belt change
  1. Polo 1.4 twist Cam belt change
    dobbie1971 Guest
    As I could never find how difficult it was to change the Cam belt on the 1.4 Polo/Lupo engine, I thought I'd put a note here.
    I'm a DIY mechanic - with exactly average ability and tools.
    Basically it was easy. The 'Special' tools needed are a pair of 8mm drill bits!! these lock the cams in place. You need a std socket set, a 4mm allen key and the 6-point tool for undoing the undertray thing and a jack/stands.
    The only hard part was undoing the crank pully bolt - jeeeez,...
    It took me a gentle 4 hrs. I think the book says 1.9 hrs.
    You will also need to do a google for a .pdf that has the instructions on it. Its called something like Lupo AFK timing belt replacement.
    finally, you can double check your work by turning the engine over by hand. Check everything still lines up. That way you shouldn't make an expensive mistake before you start it up!
    Good luck.
    D.
  2. Re: Polo 1.4 twist Cam belt change
    Can you remember what size torx socket it is for the crankshaft bolt
  3. Wink Re: Polo 1.4 twist Cam belt change
    Aug 2010
    cardiff
    [LEFT]thanks for the .pdf instruction tip will help a lot .
  1. Cost of cam belt change and service.
    By _Imran_ in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-06-2009, 12:28 PM
  2. Wife needs a Beetle! when is cam belt change?
    By degsey in forum New Member Introductions
    Last Post: 01-01-2008, 05:41 PM
  3. Polo cam belt change, recommendations for N London?
    By matt.anderson in forum Polo - Derby - Lupo - Fox
    Last Post: 26-09-2007, 03:52 PM
  4. Compensation from Audi dealer for A3 cam belt?
    By mao in forum Chat - Anything with wheels
    Last Post: 02-07-2007, 03:04 PM
  5. Cam belt change at what age/mileage
    By Johnboyc in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2007, 05:36 PM
