Thread: blowing exhaust on start up
Results 1 to 9 of 9
  1. blowing exhaust on start up
    Aug 2009
    redditch england
    Hi all! wondering if anybody has had this problem?
    my 2002 1.8t avant sounds as though the exhaust is blowing (around the manifold/turbo area) on start up. after 20 - 30 seconds the blowing stops. if i switch off the engine and then restart it there is no blowing, therefore it appears heat related.
    any ideas?
  2. Re: blowing exhaust on start up
    Oct 2006
    Cracked manifold? Could also be a leaky joint. The heat will seal it as you said. Check all the joints and nuts for a leak and tightness. Might eaven see a crack/blackend joint where its leaking from.
    A4 Avant 1.9 TDi160 for when the weather is on the damp side - Sold after 9yrs. Now A5 3.0TDI Q Sport Coupe (310bhp/480ft/lbs - Yamaha R6 for when its dry and want some 'High octane Petrol' fun.
  3. Re: blowing exhaust on start up
    130 Post(s)
    1972 Post(s)
    The secondary air injection system can make them sound odd and it shuts off if you turn the engine off and then re-start. Have you owned the car long?
  4. Re: blowing exhaust on start up
    Aug 2009
    redditch england
    had the car 3 1/2 years. definatetley sounds exhaust related. blowing stops while engine is still running so doesn't give much time to locate noise.
  5. Re: blowing exhaust on start up
    130 Post(s)
    1972 Post(s)
    It sounds like a problem in the secondary air injection system and that runs for about a minute.
  6. Re: blowing exhaust on start up
    Aug 2009
    redditch england
    don't suppose you know the best way to investigate this? will i damage the car using it with this problem?
  7. Re: blowing exhaust on start up
    130 Post(s)
    1972 Post(s)
    What is the engine code, do you have a registered copy of VAG-COM?
  8. Re: blowing exhaust on start up
    Aug 2009
    redditch england
    excuse my ignorance, but i don't have cag-com or know the engine code.
    thought i'd sorted it friday as there was a pipe off under the air filter inlet tube. i reattached it and left the car to cool down. started it later and the noise is still there, however much quieter, and again it went off after 30 seconds to a minute. sounds like the noise is coming from back left of the engine above the turbo where some pipes go around the rocker cover and into somesmall 'housings'. noise stops instantly like a valve or switch has closed
  9. Re: blowing exhaust on start up
    130 Post(s)
    1972 Post(s)
    The pipe from the SAS pump may have come off the valve on the back of the head.
  1. Attention Start / Stop - How it works
    By onemanparty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-11-2012, 03:16 PM
  2. GOLF GT TDI (150) 2002 Intermittent Poor Start
    By JamesVW in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2010, 04:53 PM
  3. Question Golf GT TDI 130 exhaust blowing
    By Duncstar in forum Golf MK4 - 1999 - 2004
    Last Post: 29-06-2009, 08:02 PM
  4. blowing exhaust
    By m_life in forum Polo - Derby - Lupo - Fox
    Last Post: 20-01-2008, 01:34 AM
  5. Audi A4 wont start
    By carenza in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2007, 03:03 AM
