Thread: Turbo Noise
Results 1 to 10 of 13
  1. Turbo Noise
    Jul 2009
    Manchester, UK
    Hey i have a 56 reg passat which has done 30,000 i have had it a couple of months now and it has always made a whistle noise when i sometimes change gear.
    Is this normal, as i thought it was until my friend asked about it, he thinks it maybe that the turbo is on its way out???
    Could this be so?? even though its hardly done any miles.
  2. Re: Turbo Noise
    May 2009
    Essex
    That noise is perfectly normal. My 06 Passat makes this noise when changing gear (only notice it when my window is down, and that had a shiny new turbo fitted recently...
    FYI turbo was replaced as it had carbon build up due to the previous owner driving the car hard and not letting the turbo cool down.
    Typically the turbos are really reliable as long as you allow them several mins of gentle driving at the end of a journey to allow them to cool down proeprly... otherwise the oil in the turbo can bake onto the turbo vanes and cause sticking...which requires a replacement.
  3. Re: Turbo Noise
    Aug 2009
    leeds
    I have just had my 06 1.9TDi in for an investigation last week into many things, turbo noise included.
    Mine makes a "wooooo" noise when changing gear at about 2000rpm, which if you wind down the window, is accompanied by a "tssshhhh" noise, not unlike the turbo dump noise you sometimes hear on souped up subaru's, only toned down a bit.
    I was concerned the turbo hose might be wearing, or a discharge of air was leaking from a gasket or something, as happenned in my last car, to only be superceeded by a complete turbo failure when the hose actually split open.
    Man in garage said perfectly fine, many vw diesel engines do this, not to be concerned.
  4. Re: Turbo Noise
    epsom,surrey
    my 2.0tdi 55plate had a turbo noise when changing gear like a dump valve noise. turned out to be the cat converter. fitted a modified cat converter noise gone.
  5. Re: Turbo Noise
    Feb 2009
    Erskine
    It is probably the air recirculation valve. Perfectly normal.
  6. Re: Turbo Noise
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by jwturpin View Post
    .,.. I was concerned the turbo hose might be wearing, or a discharge of air was leaking from a gasket or something, as happenned in my last car, to only be superceeded by a complete turbo failure when the hose actually split open.
    Wasn't a Renault by any chance?
    1996 Laguna 2.2D
    1977 MGB roadster
  7. Re: Turbo Noise
    Aug 2009
    leeds
    Quote Originally Posted by Quatrelle View Post
    Nope, 2002 Vectra, although a friends renault megane just did the same thing! lol
  8. Re: Turbo Noise
    Mar 2009
    staffs
    ive got this problem on my 56plate jetta. the fault is that the air intake pipes round & off the air box are to small and are replaced by ones off a 2.0tdi.this cures the problem im told just waiting for vw to get back to me to let me know when they are doing it for me. just hope it cures the problem as its driving me up the wall.
  9. Re: Turbo Noise
    Jul 2008
    Lancashire
    Exactly the same as my 1.9TDI!
    Is like a ghost in the engine going "woooooo".
    It did it since I bought the car last year, it was only 9 months old with 13,000 miles on it.
    It has done it ever since and I have just ignored it and it seems fine.
  10. Re: Turbo Noise
    May 2009
    uk
    i find the wastegate niose is less agressive/loud if you let off the accelerator pedal abit smother, i find if i just let off the pedal with a quick gear change, the dump valve noise is more noticable.
    this is the same in the works van too.
  1. Please Help Turbo failure again-help please!!!!!!!
    By Tyanu888 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2011, 09:18 PM
  2. 130 TDI 2004 135K Whoosh Turbo Intercooler noise...
    By robmorphet in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-05-2008, 05:09 PM
  3. Blown Turbo on AFN 1.9TDi engine?
    By justbretta in forum Archive posts
    Last Post: 18-12-2007, 04:56 PM
  4. Noise when turbo spinning accompanying power reduction.......
    By jamesmc1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2007, 07:50 AM
  5. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
