Thread: golf gttdi 140bhp 2004 poor warm starting
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 74
  1. Re: golf gttdi 140bhp 2004 poor warm starting
    Apr 2009
    essex uk
    hi,
    took off top cam belt cover today just for fun to check the two camshaft pins went in and surprise surprise one goes in and the other one is about a tooth out i wonder if this is the answer to my problems booked on on monday to be re timed
  2. Re: golf gttdi 140bhp 2004 poor warm starting
    Aug 2009
    ireland
    i have a 05 1.9tdi golf c.l and have the same problem, so i brought it to vw and they said it needed a temp sensor so they relaced that and its still doing it. so rang them and they then told me it probably needs a new high pressure pump, i asked do you mean an injector pump and they said no its a different one and it would cost around €700 for the pump alone !!!!. so im not getting that done till i get more info. i wonder is it something to do with the ecu????. or is is it the car uses some different program to start when hot compared to cold??? it has to be something simple the was never like this when i got it first. ill try to find out more and repost,or if anyone else has any ideas please post thanks
  3. Re: golf gttdi 140bhp 2004 poor warm starting
    Jun 2009
    Kington
    Hi I have just replaced DMF and clutch on my 2004 1.9tdi and have the same poor hot start problems. Any help much appreciated!
  4. Re: golf gttdi 140bhp 2004 poor warm starting
    Apr 2009
    essex uk
    hi,
    sorry to say this but this problem will never be fixed i have had to give up now after being £1800 out of pocket any way i would take my hat off to who ever comes up with the cure but one thing i have found out is that when you unplug the temp sensor with the engine hot the car starts straight away like being cold so may be that rules out crank sensor
  5. Re: golf gttdi 140bhp 2004 poor warm starting
    Aug 2009
    ireland
    gods it (lets not swear eh??) up IDS would ya be able to tell me where the temp sensor is id like to try plugging mine out to see does it work the same as your. thanks
  6. Re: golf gttdi 140bhp 2004 poor warm starting
    Aug 2009
    ireland
    sorry also forgot to ask you did they find anything wrong with the timing belt.
  7. Re: golf gttdi 140bhp 2004 poor warm starting
    #17
    Apr 2009
    essex uk
    hi,
    oh no nothing wrong with the timing vw said you cant get the 2 pins in together any way what are the 2 locking pins there for then ??
    any way they told me they re done the timing any way dont know why if it was ok may be they needed the money ?
    and next the temp sensor is just to the left under the air box if you follow the top rad hose you will see the connecter hope this helps but i am so ****** off with this car with a rough idle still and poor warm starting some one knows how to fix this .and i might even offer out a reward to get my car going smooth to some one
  8. gttdi hard to start when warm.
    #18
    Aug 2009
    dublin ireland
    hi guys, chris here in dublin, my last post was 2 weeks ago, i was finding it hard to start my mark v 2.0 gttdi when she was warm and i was looking for help i read on the forum i wasnt the only one i just tought id let you all know i got it sorted, it was my fuel injectors there was leakage in one or more of my injectors golf driving like a dream again and lots of power again
  9. Re: gttdi hard to start when warm.
    #19
    Coventry
    thanks for the follow up.
    do you have a copy of any paperwork from the dealership who diagnosed the problem?
  10. Re: gttdi hard to start when warm.
    #20
    Apr 2009
    essex uk
    hi,
    great more expense but want be changing injectors untill very sure did you have a rough idle too ?
  1. Mark 4 Golf Starting problem.
    By Oztrexx in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2008, 01:08 AM
  2. Wolfsburg Plant Produces 25 Millionth Golf
    Last Post: 28-03-2007, 07:23 PM
  3. New Golf Estate Set To Break Cover At Geneva Motor Show
    Last Post: 27-02-2007, 09:15 PM
  4. Replies: 0
    Last Post: 23-04-2005, 07:45 PM
  5. VOLKSWAGEN GOLF IS AGAIN EUROPE’S BEST SELLER
    Last Post: 03-03-2005, 09:43 PM
