Thread: Audi A3 ESP warning light
Results 1 to 10 of 19
  1. Cool Audi A3 ESP warning light
    Aug 2009
    henley
    Hi - I'm totally new to the site, and hope I've posted in the right section! I've got an Audi A3 1.8T 2000 model and the ESP warning light is staying on (Yellow Circle and Triangle). I've heard it could be a sensor. Does anyone know where the sensors are located, and if this is an expensive job?
  2. Re: Audi A3 ESP warning light
    Jan 2009
    towcester northants
    you need to get a diag test done to find out what sensor
    try marlow vw
  3. Re: Audi A3 ESP warning light
    Aug 2009
    henley
    The car is almost 10 years old, and has covered 120,000 miles, so a trip to a main dealer will be avoided at all cost, but thanks for your reply.
  4. Re: Audi A3 ESP warning light
    Jan 2009
    towcester northants
    MARLOW VW ARE A SPECIALIST
    but you need to have diag test on abs to see what fault is and the only way to check sensors is with diag machine
  5. Re: Audi A3 ESP warning light
    Jul 2009
    Yorkshire
    On my car it sometimes comes on, but goes out after a journey, don't think it is out to worry about..
  6. Re: Audi A3 ESP warning light
    Aug 2009
    henley
    Thanks Monkey, mine used to go out too, but now it stays on, it's not affecting the performance, it's just very annoying!
  7. Re: Audi A3 ESP warning light
    Cheshire
    As said above, you need a fault code read to establish which sensor is faulty....if the light is staying on, then chances are you will no longer have ABS.
    Wheel speed sensors are common failure, and are cheap and easy to fix...I did mine in 20 mins per wheel, at 36 quid each.
    Having said that, there are numerous other sensors..hence fault code read!
    You could download a freeware version of VAGCOM, and buy a lead for a tenner, then you'll be able to do your own fault codes!
    1999 Audi S3 now revo'd
  8. Re: Audi A3 ESP warning light
    Jun 2009
    Rosyth, Fife
    Quote Originally Posted by SEMKY View Post
    Hey Semky,
    I'm having a similar problem with my '05 A3 sportback 2.0 TDi - could you please point me in the right direction for getting a cable and freeware version of VAG-COM? Many thanks!
  9. Re: Audi A3 ESP warning light
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by cocksy_boy View Post
    Hey Semky,
    Or look in the Vagcom section for a member in your area...
    A4 2.5 tdi QS (mapped)
  10. Re: Audi A3 ESP warning light
    Jun 2009
    Rosyth, Fife
    Quote Originally Posted by kite View Post
    Thanks Kite, I didn't konw that section existed! I've PM'd a few people in my are so am waiting for a response. if i get no joy, how do i go about getting the free version of it and where do i get a cable from? Many thanks.
  1. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  2. New Audi A3 Cabriolet Will Be Hot Property This Summer
    Last Post: 12-03-2008, 08:23 PM
  3. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
  4. The performance SUV Audi Q7
  5. Unique look for Roomy New Audi A3 Sportback
    Last Post: 23-06-2004, 10:36 PM
