Thread: How do you reset automatic roof?
Results 1 to 10 of 13
  1. How do you reset automatic roof?
    Jun 2009
    Camberley UK
    My son tried to close the roof on my A4 cabriolet while the engine was switched off and the battery failed half way through . The AA managed to manually get the roof to close but now, even with a new battery, the automatic roof doesn't work. I have been quoted £800 by local Audi garage to fix this although they don't seem 100% sure of the problem. Any suggestions?
  2. Re: How do you reset automatic roof?
    Dec 2007
    Quote Originally Posted by katecar View Post
    best bet is to have it scanned for faults vcds
    you could try to reset the roof its in ur booklets u need to get the tool from the drivers side where fuse box is then unlock the roof at front top of screen pull middle from back seat and unlock there open fully then reclose and lock it up this should reset the roof
  3. Re: How do you reset automatic roof?
    May 2007
    knee deep in clunge
    14 Post(s)
    ignition off
    remove the osf dash end cap where the fuse box lives and there at the side of the fuse box lives the release tool
    On the front cross member above the interior mirror there is a square plastic blank
    flick the blank out and insert the tool until the cog engages the motor and turn the red part of the tool handle to engage the tool into the motor
    turn the tool anti clockwise to release the top locks and the roof will pop up a bit
    Remove the tool and get a second person to lift the roof slowly from the opposite side of the vehicle until front section of the roof is pointing upwards and at the same time lift the rear part of the roof up.
    Second person hold the roof in this position and pop the rear seat centre section out
    The tool is needed again and it locates inside the ski hatch facing upwards
    push the tool upwards again until you locate the motor and repeat the process for the front lock
    the roof box will pop up and you need to lift the lid upright and slowly allow the roof to collapse into the storage box
    close the lid and lock the motor with the tool then unlock the motor
    lift the lid and lift the roof slowly until the front section is pointing at the sky and then shut the lid down and lock the motor
    Allow the front section to drop into the front locks and lock the motor
    the roof has been opened and closed so the lock micro switches should have reset.
    Turn the engine on and open the roof fully then close it fully and that's should do it
    if the operation is still faulty then there is a fault
  4. Re: How do you reset automatic roof?
    Aug 2009
    Stalybridge, UK
    Great instructions. My 05 S4 just partially opened. Followed these instructions and it reset no probs and now works again. I didn't even know it had a manual open/close facility so was just going to roll into the garage and leave until monday. Over the moon as the kids were all ready to go to the seaside.
    Cheers A8 tech
  5. Re: How do you reset automatic roof?
    Aug 2007
    Newport, Wales
    7 Post(s)
    LOL
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  6. Re: How do you reset automatic roof?
    May 2007
    knee deep in clunge
    14 Post(s)
    lol,thats great
  7. Re: How do you reset automatic roof?
    Sep 2013
    Skegness
    Hi can any one help me I need to buy or rent/borrow a manual roof tool ASAP as my a4 cab is missing o e and guess what roof needs resetting :-( only got it last night and was rainin so couldn't check, please someone help me!!!!?
  8. Re: How do you reset automatic roof?
    Dec 2007
    where have you looked for it ?
  9. Re: How do you reset automatic roof?
    Sep 2013
    Skegness
    Quote Originally Posted by bez101 View Post
    Hi Bez typical place, drivers dash fuse box and a gaping hole where the tool should be :-( checked boot etc and still nothing :-( need kind fellow VAG assistance ASAP as they are none existant to get one?
  10. Re: How do you reset automatic roof?
    46 Post(s)
    Welcome to VWAF.
    Did you check your local Audi pars dept.?
  1. A4 Cabriolet smartTOP Remote roof top control
    By zeratul in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-05-2015, 03:38 PM
  2. Replies: 39
    Last Post: 21-07-2012, 08:17 PM
  3. roof (assoc) problems
    By daver in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 10-10-2010, 08:14 PM
  4. ## VW in the USA..... and how the UK gets ripped off..........
    By RickT in forum Chat - Anything with wheels
    Last Post: 05-03-2008, 10:18 PM
