Thread: Difference between Sport and Highline
Results 1 to 9 of 9
  1. Difference between Sport and Highline
    Jul 2007
    I'm considering buying either a Pasat estate TDI 130 in either Sport or Highline spec. But what are the differences? As far as I can see:
    Sport
    17in wheels
    sport seats?
    Highline
    16in wheels
    full leather
    There has to be more to it than this?
  2. Re: Difference between Sport and Highline
    Oct 2006
    Sunny slightly hilly Norfolk
    Sport also has lower and stiffer suspension.
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  3. Re: Difference between Sport and Highline
    Jul 2007
    Surely a B5.5 130TDI Sport has 16in wheels (mine has) and the Highline 15`s?
    The B6`s have 17`s and 16`s respectively.
    The 130TDI Sport also had the 6-speed gearbox (and 228lb/ft torque, according to the VW data supplied with the car) against the (not very nice IMO) 5-speed gearbox and 215lb/ft torque.
    The sports suspension, for me, made the all the difference to the car, being lower and stiffer, but the Highline (don`t like the name, I remember the Austin Maxi with the same moniker!) had cruise control which wasn`t standard on the Sport.
  4. Re: Difference between Sport and Highline
    agreed, the Sport has the bigger wheels with 16in tyres and 7 spoke alloys, also as mentioned the sports suspension, and sports seats, with the higher torque engine, mine was checked at 215 or so on a rolling round, with 135bhp, which is now up to 170bhp, and nearly 270 torques (thanks Mark from chip n' Spin)
    if you can get one with leather seats all the better, which should come with heating which helps in the Winter months
  5. Re: Difference between Sport and Highline
    Aug 2008
    I have a 54 Highline TDi 130, there is no cruise control.
    2004 Passat Highline TDi 130 - Bog Standard
  6. Re: Difference between Sport and Highline
    Sep 2008
    Is it the 6 speed gearbox or the sport engine itself that has the higher Torque??
  7. Re: Difference between Sport and Highline
    Jul 2007
    It may be cobblers, but I was told by a VW guy that the reason for a lower torque figure for vehicles with the old 5-speed box was down to the box having a lower max. torque rating, i.e it was getting close to what VW reckoned was a safe limit to ensure longevity and reliability.
    The 6-speed being a newer design can handle the higher torque levels of the modern engines.
    Apparently.
  8. Re: Difference between Sport and Highline
    Aug 2008
    If thats true i would be worried about having a remap!
  9. Re: Difference between Sport and Highline
    Aug 2007
    Does the Highline also have the aluminium dash/door handle area trim which the Sport has?
  1. Question MFD Display
    By GeoffW in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-11-2011, 10:52 AM
  2. 55 plate SE standard equipment.
    By Dozz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-05-2009, 10:44 PM
  3. Sport or highline / 140 or 170 / TDi or CR / DSG or manual
    By ian5509 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-03-2008, 03:25 PM
  4. 130 Sport TDi - is the suspension lowered?
    By lard-ajc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2008, 10:30 PM
  5. New to Bora's
    By redtony in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-06-2007, 03:37 PM
