Thread: Engine Codes
  1. Engine Codes
    Feb 2009
    Leeds, UK
    Hi all,
    I have a Golf Mk3 1.6 SE. The car was orignally a 1.4 but has had the engine swapped.
    The engine code on the sticker in the boot reads AEX which is the old 1.4 engine.
    The engine code on the cambelt cover reads AEE which is a 1.6
    However, inorder to change the spark plugs on my engine you have to remove the air cleaner/throttle body air box to gain access. I believe that this only has to be done on engines ABU, ABD and AEA (am I wrong to believe this?).
    Any ideas about which engine type you think I have?
    Matt
  2. Re: Engine Codes
    Dec 2008
    Stockport
    I'd go with the cam cover sticker and say you have an AEE. Plus I think the AEE is close to the AEX as far as alternatives go, so it would be a reasonable swap.
    Where did you get the info about which engines you have to remove the air filter body from? If it was the Haynes manual, it is short of info especially on the AEX.
    On my AEX and AEE, to access the spark plugs just unscrew the 4 numbered screws on the air filter body. There is a rubber pipe on the bottom which is part of the crankcase breather system which just pulls off. If you still have it, the warm air pipe from the exhaust manifold to the air inlet also just pulls off. (Or falls off in a lot of cases apparently). The leads and plugs are then accessable.
  3. Re: Engine Codes
    Feb 2009
    Leeds, UK
    I got the info about removing the air filter body from a Haynes Manual.
    When changing the spark plugs a few weeks ago I had to unscrew the 4 number screws you mentioned so it sounds like I have an AEE engine.
    Thanks a lot for your help!
    Matt
  4. Re: Engine Codes
    Dec 2008
    Stockport
    I would think the only definitive answer would be the engine serial number but I think it's on the back of the block and is a pain to read. Might be possible with a small mirror, I really can't remember.
  1. "How To" The FAQ & How To Thread
    By Ben in forum General
  2. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  3. Engine Codes
    By t0m541 in forum Audi A3 - Archive Topics
    Last Post: 27-09-2007, 10:45 PM
  4. Engine Codes - Probably a daft question
    By jamescurrer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-07-2007, 09:55 AM
  5. Newbie - first post- looking to buy!
