Thread: 2005 1.6 ikon engine number location???
Results 1 to 10 of 11
  1. 2005 1.6 ikon engine number location???
    Jun 2009
    melbourne, australia
    Hi all,
    I have a 2005 1.6 auto beetle, and im having great difficulties locating the engine number. can someone please enlighten me on its whereabouts?????
    thanks
  2. Re: 2005 1.6 ikon engine number location???
    Jan 2009
    towcester northants
    there should be a sticker on the cambelt cover or in the spare wheel well
  3. Re: 2005 1.6 ikon engine number location???
    Jun 2009
    Quote Originally Posted by towcestervag View Post
    Thanks for your reply, i have found the sticker however i need to find the engine number on the engine block??
  4. Re: 2005 1.6 ikon engine number location???
    Jan 2009
    towcester northants
    have a look at top of cylinder block where it joins cylinder head about mid point you may have to use scrapper to clean area
  5. Re: 2005 1.6 ikon engine number location???
    Jun 2009
    thanks again towcestervag! can you please give me a bit more detailed description, as in if im looking at the engine bay is it on the right, left, front, back of the engine?? sorry if i sound stupid, but i know nothing about the beetle!!!
    cheers
  6. Re: 2005 1.6 ikon engine number location???
    131 Post(s)
    1973 Post(s)
    Almost impossible to find even with the engine out, why do you need to find it? If it is a UK registered car and you PM me the reg I should be able to give you the full number.
  7. Re: 2005 1.6 ikon engine number location???
    Jun 2009
    hi
    i am from victoria australia, and in order to transfer the vehicle into my name, i have to obtain a Roadworthy Certificate which requires to confirm the engine number on the engine matches with the engine number on the paper work.
  8. Re: 2005 1.6 ikon engine number location???
    Jan 2009
    towcester northants
    sorry i told a lie
    the engine no is located below coil pack on flat by oil pressure switch it would be AYD if gb spec
    look at the area below coil pack just where the gearbox bolts to the engine
  9. Re: 2005 1.6 ikon engine number location???
    Jun 2009
    sorry i told a lie
    It is a BFS engine?? would it be in the same location?
  10. Re: 2005 1.6 ikon engine number location???
    Jan 2009
    towcester northants
    just checked on elsa in same place according to that
  1. bora engine number location
    By Bora Boy in forum Bora - 1998 - 2005
    Last Post: 13-10-2007, 08:49 PM
  2. Audi Cuts New A3 Engine Down To Size
    Last Post: 14-08-2007, 10:18 PM
  3. Wanted: AVU 1.6 A3 Engine + Advice needed
    By Raspeir in forum Audi A3 - Archive Topics
    Last Post: 23-06-2007, 12:06 PM
  4. Volkswagen Tsi Claims Category Honour In Engine Awards
    Last Post: 12-05-2007, 08:40 PM
