Thread: Polo 9n Air con Problems
Results 1 to 10 of 12
  1. Polo 9n Air con Problems
    Jun 2009
    Notts
    Well i have a 1.9tdi Polo 9n with no aircon working.. Its been re-gassed with no leaks and no problems that side.. only found that at the connector to the aircon unit that the voltage is 10.4v all the time wether aircon is on or off.. Any ideas anybody..
    regards
    Willowraf
    mk1 golf cab 1.8t
    polo 1.9tdi stage 2
  2. Re: Polo 9n Air con Problems
    Check the fuses on the fuse holder on the battery,these have a tendency to corrode
  3. Re: Polo 9n Air con Problems
    Jun 2009
    Notts
    Quote Originally Posted by kenney View Post
    Good call... the corrission would of caused the volt drop.. but just checked and in this case no corrosion. Also it has 10 volts with both A/C selected or deselected???????
    cheers though it was somthing i had not check before having to change the controller...non climate controller that is..
    cheers
    MK1 CAB.. 1.8tt (AUM) - TT back box - Full TT dash - Intergrated TT lights - Full Koni Suspension - 928 Rims - Porsche Brakes converted to 280mm - DTA ECU - ABS sensors all round but not used for braking - Full electric Pack.. Loads more..
  4. Re: Polo 9n Air con Problems
    Jun 2009
    Notts
    Any other ideas on this one?? Should the air con always have a live feed?? Does it have any relays in the system which maybe hard latched on?? Anybody had this fault before??
    Regards Tim
  5. Re: Polo 9n Air con Problems
    Is it climatronic you have?There is no relay,in addition to the fuses i mentioned,check fuse 18 on the fuse board.Can you run a diagnostic check?
  6. Re: Polo 9n Air con Problems
    Jun 2009
    Notts
    No its the standard A/C button type..not the climatronic control....I'll check the fuse now... cheers I thought it was fuse 29..but i'll check it anyways... I'll also do a Vag scan..No error's last month after the Ecu fried.. But it's always worth a look...
  7. Re: Polo 9n Air con Problems
    Jun 2009
    Notts
    Well i've change the controller which made no changes to the state of the system...boo...Has anybody got and wiring diagrams for this system as it's lost list in the hynes manuals... Also i've ran the system through Vag-com...Not apparent faults... So i'm still get 10.4 volts and A/C source and the pressure is stayiny stable at 100 psi which indicates compressor failing to work...Any other ideas to fix...Or any ways to test the compressor???
    Regards Tim
    I hate A/C
  8. Re: Polo 9n Air con Problems
    Need your e-mail address,to send the diagram
  9. Re: Polo 9n Air con Problems
    Jun 2009
    Notts
    willowraf@ntlworld.com
    cheers
  10. Re: Polo 9n Air con Problems
    Jun 2009
    Notts
    Cheers for the diagrams....Now i can confirm the worst case is that the compressor has failed....boo.. £350 for quick fix no so good...
    Thanks again..
  1. Climate Control / Air Con Unit
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-07-2009, 12:29 PM
  2. Air con fuse blown, now no air co even after fuse replaced
    By HomerSimpson in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-06-2009, 08:22 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. air con problem
    By eddie v twin in forum Touran - Sharan - Caravelle
    Last Post: 18-05-2008, 07:56 AM
  5. smelly air con
    By mac g in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-02-2008, 04:51 PM
