Thread: How to bleed Hydraulic roof system golf cabrio
Results 1 to 10 of 15
  1. How to bleed Hydraulic roof system golf cabrio
    As per title really.
    My electric roof stopped working so I bought the correct fluid and topped it off, this solved the problem albeit temporarily but I've now had to top it up again so I'm guessing there's a leak somewhere (should be fun to find). I just wondered if anyone could tell me how to bleed the system once I have refilled it? I can't find this information anywhere - doesn't it need bleeding? Also, is there a correct way to reset where the roof is after you've released the pressure from the system using the handle in the boot.
    Thanks in advance for any help.
    Dan
  2. Re: How to bleed Hydraulic roof system golf cabrio
    Jan 2009
    towcester northants
    the leak is probably from either the reservior they crack or the rams remove the rear seat base and check for fluid underneath
    to bled release the screw on the side of the pump and operate the roof manually several times
  3. Re: How to bleed Hydraulic roof system golf cabrio
    brilliant. thanks for your help. I'll do that in the morning.
  4. Re: How to bleed Hydraulic roof system golf cabrio
    If it is the rams do you know an approximate cost for a replacement?
    thanks
  5. Re: How to bleed Hydraulic roof system golf cabrio
    Jan 2009
    towcester northants
    no probs hope it helpfull
  6. Re: How to bleed Hydraulic roof system golf cabrio
    131 Post(s)
    1973 Post(s)
    The rams are £194 each.
  7. Re: How to bleed Hydraulic roof system golf cabrio
    Bloody hell, that seems a lot! Is it possible to get the originals resealed?
  8. Re: How to bleed Hydraulic roof system golf cabrio
    131 Post(s)
    1973 Post(s)
    No idea, I have only ever done a couple in all the years they have been out, normally the leak is a cracked reservoir on the pump. Is the boot floor wet with fluid?
  9. Re: How to bleed Hydraulic roof system golf cabrio
    Hi, I checked under the seat and there is hydraulic fluid on the passenger side so I guess it's the passenger side ram. I assume these can be replaced one at a time? From looking at it to replace it do you just remove the trim panel from the side that's broken and then disconnect the hose and unbolt the ram. Reversing to replace the new one before topping up and bleeding the system?
    Also, I don't suppose you have a part number? Thanks again for all your help, it's typical that we get this great weather and this happens!
  10. Re: How to bleed Hydraulic roof system golf cabrio
    131 Post(s)
    1973 Post(s)
    Which year?
  1. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  2. New audi s4 raises the benchmark for handling dynamics
  3. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
  4. New Golf Plus is show surprise at Bologna
    Last Post: 05-12-2004, 08:17 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
