Thread: Intermittent centre brake light on A4 cab
Results 1 to 10 of 10
  1. Intermittent centre brake light on A4 cab
    I keep getting this problem on my 52 plate cab. Normally the first time I press the brake pedal on a journey and then it disappears (possibly dirty/loose connection?) Has anybody else had this and fixed it? I can't see any easy way to check the light assembly for loose connections, can anyone advise on the easiest way to do this?
    Thanks...
  2. Re: Intermittent centre brake light on A4 cab
    have you checked the brake light switch?
  3. Re: Intermittent centre brake light on A4 cab
    No, I haven't. Is it a mechanical one at the pedal or hydraulic positioned elsewhere?
  4. Re: Intermittent centre brake light on A4 cab
    Southern County Softy
    20 Post(s)
    Clean up ALL bulb holders on both rear lights...
    A4 2.5 tdi QS (mapped)
  5. Re: Intermittent centre brake light on A4 cab
    Would that throw up a fault for the centre light?
    One of the rear light bulbs has 'gone' a couple of times but a tap to the cluster and it comes back on fine and it gave the correct fault warning...
  6. Re: Intermittent centre brake light on A4 cab
    20 Post(s)
    I've had wrong bulb warnings on an A3 and an A4.
    Tapping the bulb has probably fixed a broken element in the bulb, change it.
  7. Re: Intermittent centre brake light on A4 cab
    OK, I've replaced bulbs and cleaned up terminals but still get this problem occasionally. Particularly annoying to trace any fault if it isn't there when I come to check it!
    The one time it came on at the end of the journey, I gave the boot lid a bang and it started working again. Has anybody had faults on the LED pcb or connections?
  8. Re: Intermittent centre brake light on A4 cab
    I'm pretty sure I've fixed this now... Took the LED strip out and dismantled it, it all clips together so this is fairly easy. The connector at one end of the pcb has its pins soldered into the board, each pin had 2 solder points and all 4 joints had cracked! Quick job with a soldering iron and it's all back together and I haven't had the fault again.
    Hope this helps somebody else!
  9. Re: Intermittent centre brake light on A4 cab
    Nov 2010
    staplehurst uk
    Haven't tried it yet but will do.
    how does the led cluster come out?
    thanks
  10. Re: Intermittent centre brake light on A4 cab
    I can't remember the exact sequence but you have to remove the inside boot lining and it unbolts from inside. It should be fairly obvious once you get in there... It's then a case of unclipping the housing to get the led strip out and re-soldering.
  1. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  2. Polo brake light fuse problem
    By iandy in forum Polo - Derby - Lupo - Fox
    Last Post: 09-04-2008, 02:12 PM
  3. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  4. The performance SUV Audi Q7
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
