Thread: Changing the brake light bulb
Results 1 to 10 of 14
  1. Changing the brake light bulb
    Jan 2009
    OK, I'll have to admit to being stupid first.
    I've searched here, and I've googled repeatedly, but I can't for the life of me remove the rear cluster.
    Every post I read (including a very detailed set of photos), refers to there being a retaining screw behind the access hole, as does the handbook.
    My car (Nov 07 A4 Avant - 2.0 TFSI, S-Line) doesn't have anything that a screwdriver (flat or cross) will fit into. In fact, it has what looks like a big plastic inverted nut kind of thing in there. I'm not sure what you'd call it but it's like something you'd need to use a very large allen key on. Size wise, it's the same size a wheel bolt head, but I've no idea what kind of tool I need to be able to undo it.
    I'd appreciate any suggestions that will save me handing over £30+ to the dealer.
    Thanks.
  2. Re: Changing the brake light bulb
    Jan 2009
    You will find the tool that you need is the handle of the screwdriver in the kit with the spare wheel.
  3. Re: Changing the brake light bulb
    Norwich
    Look in the manual page 322 has instructions
  4. Re: Changing the brake light bulb
    Dec 2008
    @classiccarguru1
    If you've lost Hex key tool, there IS a small flat blade screwdriver slot at the bottom of the hex hole, that you can use to unscrew the cluster retaining bolt.
  5. Re: Changing the brake light bulb
    Jan 2009
    Thanks for the suggestions.
    The screwdriver handle has a hex recess i.e. it fits on a hex bolt the same size as a wheel bolt and it's a tool with a hex head (like a wheel bolt) that is needed to undo the part that holds the light cluster in place.
    Page 322 of my handbook doesn't have anything to do with changing light bulbs; but thanks for the suggestion.
    Despite messing around for ages, I can't find anything in there that a small flat bladed screwdriver will get into.
    For now at least it's not a problem because the outragously expensive dealer replaced the bulb under warranty
    I thought I'd post this as it might help someone else.
  6. Re: Changing the brake light bulb
    Norwich
    I'll scan the pages for you when I get home tonight if you want, strange that your manual does not have these instructions, unless they deliberatly cut out this useful DIY tips in a later revision for suspicious reasons i.e. force you to go to dealer.
  7. Re: Changing the brake light bulb
    Jan 2009
    It'd be interesting to see, thanks. It does seem that not only do parts change during the production run of a model, but also the relevance of the manual. The drawing in my manual is most definately not what I see in the car..........I should take a photo really, because everything I've found via Google refers to there being an obvious screw behind the removeable cover in the boot.
    Maybe there was a design change? It seems the screw removal was a bit fiddly and it appears the big plastic hex socket would be easier to remove and replace..........with the right tool !
  8. Re: Changing the brake light bulb
    Norwich
    OK PM me your email address for the instructions about changing the rear bulbs in the side panel.
    They do mention a special retaining screw that secures the light cluster, but only tool they mention is the screwdriver in the vehicle toolkit.
  9. Re: Changing the brake light bulb
    Norwich
    OK took a look at my car just now 2006 A4 Avant and this is what I found:
    A hex nut which does indeed have a slot for the flathead screwdriver in it.
    OR
    The locking wheel nut hex head fits in it so you will need a hex piece that size to undo it.
  10. Re: Changing the brake light bulb
    Jan 2009
    I am sure that a hex tool is in the toolkit - the handle of the screwdriver if I remember correctly.
  1. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  2. Near side Brake light
    By xerian in forum Beetle 2000-
    Last Post: 18-04-2009, 05:39 PM
  3. Touareg intermittent third brake light
    By Toe-Rag in forum Touareg
    Last Post: 14-04-2009, 11:05 AM
  4. Passat brake light bulb replacement
    By nobbythecat in forum Passat - Archive Topics
    Last Post: 13-01-2008, 09:05 PM
  5. RS6 Brake Light Bulb Replacement
    By rief944t in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-07-2007, 08:37 AM
