Thread: Cylinder 2 Misfire
  1. Question Cylinder 2 Misfire
    Hi everyone,
    I was driving home earlier and the light came on the dash (emissions I think) and the car went into 'limp mode'.... Very little power etc.
    When I got it home I did a scan on VAG COM and it gave me the fault code of '16686 - Cylinder 2 Misfire Detected'.
    Now what next? Do I replace the spark plugs first?.... then the HT Leads?
    And then leave the coil pack untill last?
    Any help would be great as I have to use the car for tuesday. Thankyou
    Oh and finally.... the spark plugs don't seem to be the easiest things to get to, does anyone have a guide? I have a 1.6 8L 2001 A3.
  2. Re: Cylinder 2 Misfire
    Southern County Softy
    20 Post(s)
    Change the No2 coil first, these are known to fail.
    A4 2.5 tdi QS (mapped)
  3. Re: Cylinder 2 Misfire
    May 2007
    knee deep in clunge
    14 Post(s)
    No coil packs on this model and i would suggest renewing all the leads first because if you have no experience of removing theses leads you will destroy them on removal.When removing the plugs make sure the washer on the spark plug is present as they tend to stick in the cylinder head thread
    Check the plug leads are installed firmly and no arcing out on the cylinder head as you can see theses plugs/leads are a pig to access.Consider a compression test to eliminate valve leakage and be careful you don't catch the injectors when working in this area as the connections are prone to damage from accessing the spark plugs.good luck and watch those knuckles lol
  4. Re: Cylinder 2 Misfire
    20 Post(s)
    Opps.....me bad....
  5. Re: Cylinder 2 Misfire
    Right Update
    I have tried swapping the HT lead with number 1 and its still showing misfire on cylinder 2, have also changed the coil pack and no luck!
    Would a faulty spark plug be the cause? They were only changed about 6 months ago with decent NGK ones...
    What other things should I check guys? This is a little worrying as I don't want to go down the "new engine" route
    Car has done 55,000 miles if thats any help.
  1. 2004 Golf Mk4 1.4 Match - Misfire & Brake Switch Errors.
    By mlilburn in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2009, 08:45 AM
  2. Golf 2003 1.6 Match - Cylinder 4: Misfire Detected
    By blozza in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2008, 06:03 PM
  3. Misfiring Mk4 1.8T
    By Shleng in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2008, 11:17 PM
  4. Random/Multiple Cylinder Misfire Detected
    By mercaudi40 in forum A8 - S8 - V8
    Last Post: 23-01-2008, 05:46 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
