Thread: MK 5 Golf timing belt or chain
Results 1 to 10 of 10
  1. Question MK 5 Golf timing belt or chain
    Apr 2009
    Rutland
    Hi, just acquired a MK 5 2.0 GT Tdi with 41k miles. My question is, does the engine have a cam belt or timing chain and when should it be changed?
  2. Re: MK 5 Golf timing belt or chain
    Canada
    Belt.... What year is it? Mines a 2006 140 and its a belt
  3. Re: MK 5 Golf timing belt or chain
    Apr 2009
    Rutland
    Quote Originally Posted by onzarob View Post
    It's a 2005 140bhp, when does it need changing?
  4. Re: MK 5 Golf timing belt or chain
    Canada
    needs changing at 4 years or 60K. so if its not been done then best to get it done soon
    You will see lots of post about timming belt change intervals, but it will cost around £400 at a dealership, but if it breaks it can cost £3k to fix.
    HTH
    Rob
  5. Re: MK 5 Golf timing belt or chain
    May 2008
    my service manual states that the interval is 80k for the 2.0 TDI, which this is, and 60k for the 1.9TDI. Unless they changed them as mine is an 04 plate 140?
    VW recommend a 4 year interval if that comes up 1st, but it doesnt say this in the manual.
  6. Re: MK 5 Golf timing belt or chain
    Canada
    As I said before ther are lot of conflicting messages about cambelts
    see this thread for all of them https://www.vwaudiforum.co.uk/forum/s...ad.php?t=52096
    I still think 4 years or 60K is the safest route and as sated £400ish to do is better than £3K+.
    Rob
  7. Arrow Re: MK 5 Golf timing belt or chain
    shaft-50 Guest
    as the rob man says better to be safe than sorry and the norm is 60k miles or 4 years.
    try getting a quote from a vw approved repair centre, they are usually 50% cheaper (labour) than dealers.
  8. Cool Re: MK 5 Golf timing belt or chain
    Apr 2009
    NZ
    Quote Originally Posted by missilemary View Post
    They have cambelts and the change intervals are 180000kms per factory spec but as a mechanic myself I would still use the old spec and change it at 120000 or five years to be on the safe side! VW can say 180000 because by that time it will be long out of warranty so if it then snaps it is the owners problem! VW here in NZ does just that with imported VWs as opposed to the NZ new models.
  9. Re: MK 5 Golf timing belt or chain
    Dec 2006
    Quote Originally Posted by Benzev View Post
    180,000 kms.... thats high!!
    60k miles is best or 4 years...
    Rick
  10. Re: MK 5 Golf timing belt or chain
    Feb 2009
    Vee Dub have changed it to 5 years i believe in between belts, im having mine done and my water pump for £230 on saturday
  1. First Facts on the Golf BlueMotion:
    Last Post: 13-08-2007, 07:08 PM
  2. Timing belt tensioner problem
    By gbrownlee in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:43 PM
  3. 1994 golf 1.8L timing marks
    By blake carstense in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-05-2007, 09:00 AM
  4. 80 timing belt guarantees
    By Confiteor in forum 80 - 90
    Last Post: 02-12-2006, 12:17 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
