Thread: Power Window Switch Pin Layout
  1. Power Window Switch Pin Layout
    Apr 2009
    Porthcawl
    Hi All,
    Yesterday I picked up a 2001 VW T4 camper which has had aftermarket electric windows fitted. I belive that the switches used are from a Passat. Unfortunately one of the switches has become disconnected whilst trying to rectify a problem and I’ve only managed to blow the fuse for the windows when trying to reconnect the switch.
    Does anyone know the layout of the pins on the switch?
    From what I’ve managed to get together so far today is what I’ll be trying tonight.
    Outer pins - motor
    Next ones in -ve
    Middle +ve and illumination
    Many Thanks,
    Paul.
  2. Re: Power Window Switch Pin Layout
    Norfolk
    One passat switch has 4 pins. Numbered left to right. 3, 1, 2, 4.
    3. Switch illumination
    1 & 2. Up and down
    4. Power
    Is this like your switch.
  3. Re: Power Window Switch Pin Layout
    Apr 2009
    Porthcawl
    The layout is 6 pins set out :-
    _
    _
    l l
    _
    _
    Sorry about the cr#p pic, but I can't get the pdf small enough to attach.
  4. Re: Power Window Switch Pin Layout
    Norfolk
    Looks like you will have to run a resistance test on the pins to work out what they do. The passat switch only has 4 pins arranged in two rows. Three pins in top row, one in bottom row.
  5. Re: Power Window Switch Pin Layout
    Apr 2009
    Porthcawl
    similar to the pin layout in the image.
  6. Re: Power Window Switch Pin Layout
    Norfolk
    Quote Originally Posted by chudsy View Post
    That's not the pin layout I recognise for a passat switch. Just measure the resistance between pins when you move the switch. That will tell you what connects to what.
  1. Power window switch failure
    By Canetoad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-04-2009, 07:41 AM
  2. Power window problem
    By erico in forum Early Passat Forum - Pre 97
    Last Post: 19-04-2008, 09:25 AM
  3. Towbars and electrics
    By foxyloxey in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 14-04-2008, 07:55 PM
  4. Replies: 0
    Last Post: 02-04-2008, 02:14 PM
  5. How does the Quattro system work?
