Thread: Climatronic - just how does it work?
Results 1 to 10 of 11
  1. Climatronic - just how does it work?
    Mar 2009
    I've been searching, but not yet found the answer, so hope someone can help!
    Had my Passat (2002 - 2.0 S estate) for about 6 weeks now, and the heater part of the Climatronic system seems to work fine.
    However, having now had a couple of warmish days, I'm now not sure I understand how the Climatronic unit is supposed to work...
    What do the AUTO and ECON buttons do?
    AUTO seems to put the selected temperature up to 22 degrees, and ECON doesn't seem to do anything!
    I've tried using the "cooler" button to bring the temp to "LO", and, on a couple of occasions, I've had an "Icey blast" for about 30 seconds, and then the air seems to "warm up" to about the same temp as the external air temp. The rest of the time, I just get "external ambient" air...
    Is this indicating a possible fault (ie. the system needs re-gassing) or is this how its supposed to work?
    Andrew
  2. Re: Climatronic - just how does it work?
    Jul 2008
    Auto = set the temp and the climate will automatically keep your cabin at that temperature by either heating or cooling using aircon or external air and openning/shutting the external air intake.
    Econ = set the temp you like and it will TRY and do the above without using the aircon - so less fuel is used . It wont be able to cool the cabin to lower than the external air temperature though.
    HTH.
  3. Re: Climatronic - just how does it work?
    Mar 2009
    Thanks...
    I've noticed that if its on AUTO, and I drop the temp to "LO", the AUTO switches off... is this correct? Is 18 deg the lowest that AUTO can work to?
  4. Re: Climatronic - just how does it work?
    Jun 2006
    UK, Mids
    Quote Originally Posted by abucksdiver View Post
    Thanks...
    Yes, because LO will try to make the cabin as cool as possible, so AUTO would be a contradiction.
    Audi A8 - 2015 - 3.0TDI
  5. Re: Climatronic - just how does it work?
    Mar 2009
    Quote Originally Posted by snapdragon View Post
    Hmmm... maybe I need to pay more attention to the Climatronic settings... if I set it to low, but econ is on, then external ambient will be the lowest it can get too...
    I'll do some more experiments with ECON and AUTO...
    Thanks guys
  6. Re: Climatronic - just how does it work?
    Tyldesley, Manchester, UK
    Thanks guys
    Yes that is correct. ECON simply means the compressor on the A/C is not used, it will do it's level best to cool to the set temp using external ambient only. It will of course heat the cabin up just as well as AUTO would.
    One German, Two Italian.
  7. Re: Climatronic - just how does it work?
    Jun 2006
    UK, Mids
    In LO, you can have ECON or (blank).
    If blank, the A/C will run, if ECON it will not.
    AUTO also automates the flap positions and fan speed, but LO overrides this with full fans, no heating, A/C if not on ECON.
    Also, you see the small grilles on the front of the climate control? There is a tiny fan inside which sucks air in the right and expels it on the left after passing it over a temperature sensor, this can get clogged up with dust, so blast it out with compressed air, and when you hoover the car, suck on these grilles.
    It's not the greatest climate control.
  8. Re: Climatronic - just how does it work?
    Jul 2007
    Co Durham
    May be not the greatest but it's a lot better than I had in my previous car, an E39 BMW 5 series! I think it's great.
  9. Re: Climatronic - just how does it work?
    ChillOut Guest
    I would advise against "blasting" - you might damage something, but for sure, give those grills a gentle hoover with a brush.
    I'd say the climate control is pretty good actually - set mine to auto almost all the time. Some points:-
    Auto only uses the A/C pump when it needs to, so is not an uneconmic as old on/off aircons.
    It also uses A/C to control excess humidity, to keep your windows clear of mist, so use it all the time if you don't like living in a soggy place in winter ( or a summer like last year)
    You must use A/C as least once a week or the pump can fail - don't ask me why, its just true - friend of mine is an eco warrior and did not use AC unless in dire need - he's bu$$ered two AC pumps now. Using Climate is more economical than having a window open and having the correct humidity and temp prevents drowsiness and falling asleep accidents, not to mention keeping the mist off the windows also adding to safety.
  10. Re: Climatronic - just how does it work?
    Jul 2007
    Co Durham
    The seals dry out and can eventually fail in the compressor if not used regularly. I presume leaving Climatronic in Auto will always ensure that the compressor runs regularly?
  1. Climatronic wont work unless its cold
    By guido75 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-12-2007, 05:06 PM
  2. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  3. Climatronic problems
    By nice red GTi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-04-2007, 02:46 PM
  4. @))@ Passat Electrical Bug
    By dp5010 in forum Passat - Archive Topics
    Last Post: 20-10-2006, 02:40 PM
