Thread: How to replace Passat Rear Shock Absorbers
  1. Exclamation How to replace Passat Rear Shock Absorbers
    High Wycombe, UK
    Hi all!
    apparently this is fairly easy to do
    can anyone help / give me a guide with pics preferably
    i've been told both my rear shocks are leaking
    as you can see i'm not great with cars but want to learn
    thanks
  2. Re: How to replace Passat Rear Shock Absorbers
    ChillOut Guest
    Its really very easy. Best advice get the haynes manual which gives a step by step guide.
    Although, a good indepenent should charge very little on top of the parts price - a pro would take about half an hour I reckon to do both.
  3. Re: How to replace Passat Rear Shock Absorbers
    High Wycombe, UK
    i have a tdi 130 sport 03 plate
    is there a specific shock that i need to buy?
  4. Re: How to replace Passat Rear Shock Absorbers
    Jun 2006
    UK, Mids
    The original VW ones are Bilstein or BOGE/SACHS.
    You can get these from Eurocarparts or GSF for about £35 each. http://uat.eurocarparts.com/ecp/c/Vo...hock-Absorbers
    They are so easy to do if you have the tools and jack, as said, it may be worth asking a fast fit place how much it would cost and also ask what make the parts are and if you can supply your own.
    Audi A8 - 2015 - 3.0TDI
  5. Re: How to replace Passat Rear Shock Absorbers
    High Wycombe, UK
    fast fit places asking for 50 quid fitting both rears, if i supply parts
    otherwise 200-300 quid quotes (ridiculous!!), if they supply
    i think i better learn how to do it myself
    can anyone give me a clear talk-through as i think im gonna try it myself
    what tools do i need?
    cheers
  6. Re: How to replace Passat Rear Shock Absorbers
    Jun 2006
    UK, Mids
    Jack up the back end or the back corner and support on axle stands.
    Remove the wheel.
    Remove the lower single nut & bolt that holds the strut to the hub.
    To remove the bolt, you will need to either position a trolley jack under the hub and lift it up a few mm, as the force the spring will jam the strut down and you can't get the bolt out or put it back in.
    Remove the two upper bolts, these are up in the top of the wheelarch through an aluminium casting at the top of the strut.
    The strut will now drop out. There are no bolts in the boot like most cars.
    Remove any parts off the old damper which you need to transfer to the new one. (bum stop, boot, top mount etc...).
    Give them a clean, and clean in the top of the wheel arch so that you don't get dry mud etc.. trapped.
    USE Loctite threadlock on all bolts and nuts unless you replace them with new ones which have the threadlock coating already on them!
    Refitting if reversal of removal.
    Mark beside the bolts and nuts with paint which will crack if they start to undo.
    2 1 0
  1. "How To" The FAQ & How To Thread
    By Ben in forum General
  2. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
  3. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  4. VW Passat Rear Brake & Tyre Wear
    By VWItaliano in forum Archive posts
    Last Post: 23-10-2006, 12:20 PM
  5. First Pictures of the New Passat Revealed!
    Last Post: 15-12-2004, 12:10 PM
