Thread: Easy way to tell if it's Lucas or ATE brake system
Results 1 to 10 of 10
  1. Easy way to tell if it's Lucas or ATE brake system
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Ello all,
    Is there an easy way to tell if a car has the Lucas or ATE system fitted and thereby determine which brakes to get?
    If I select the correct Chassis range for my car at Eurocarparts I'm presented with two options...... Which boil down to ATE or Lucas.
    Cheers,
    Dan.
  2. Re: Easy way to tell if it's Lucas or ATE brake system
    7 Post(s)
    Front or rear brakes ?
    Easiest surest way is to whip a wheel off and have a look. Lucas or ATE will be stamped on the caliper but might take some finding amongst the grime.
  3. Re: Easy way to tell if it's Lucas or ATE brake system
    Aug 2007
    15 Post(s)
    Quote Originally Posted by BigCol View Post
    Yes - all need doing For some reason Murrays were able to quote me the parts directly, but ECP seem to offer the choice.....
  4. Re: Easy way to tell if it's Lucas or ATE brake system
    Have a look at the brake fluid reservoir,it should be on there.
  5. Re: Easy way to tell if it's Lucas or ATE brake system
    london/ UK
    ATE calipers have a wire spring/clip on the outside of the caliper visible if you have alloys. The Lucas dont have that...
  6. Re: Easy way to tell if it's Lucas or ATE brake system
    Aug 2007
    15 Post(s)
    Quote Originally Posted by adamss24 View Post
    between that and the answer above yours I think I might have an answer then
    Cheers all!
  7. Re: Easy way to tell if it's Lucas or ATE brake system
    Nov 2008
    N/A
    I went to ECP and the guy told me the same and I had no clue - he went out and knew as soon as he looked at them!
  8. Re: Easy way to tell if it's Lucas or ATE brake system
    Aug 2007
    15 Post(s)
    Having braved the sheet weather I can quite clearly see the ends of a relatlivey thick spring clip top and bottom so I assume ATE it is then
    Thanks!
  9. Re: Easy way to tell if it's Lucas or ATE brake system
    london/ UK
    Why dont you post a picture if not shure ?
  10. Re: Easy way to tell if it's Lucas or ATE brake system
    Aug 2007
    15 Post(s)
    Bloody good idea and were it not dark outside I would do :-) Tomorrow would seem favourite....don't want to have the police knocking on my door asking what I'm doing taking photos of a car at this time of night!!
    Dan.
  1. Bleeding brake system!
    By day in forum Golf MK4 - 1999 - 2004
    Last Post: 28-07-2018, 04:04 PM
  2. Lucas brake issue with S4
    By pmwilbur in forum Archive posts
    Last Post: 08-01-2008, 04:07 AM
  3. Brake System
    By peyton1115 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-11-2007, 11:08 AM
  4. New Passat - Parking brake system fault warning - Advice please
    By jarnelljones in forum Passat - Archive Topics
    Last Post: 05-09-2007, 07:41 PM
  5. A4 Brake System Warning Light
    By lastyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2007, 12:38 PM
