Thread: A6 2.5 TDi AFB Won't Start
Results 11 to 20 of 25
  1. Re: A6 2.5 TDi AFB Won't Start
    #11
    Mar 2009
    Kidderminster, Worcestershire and Tewkesbury, Gloucestershire
    Ok I checked the lift pump, it's drawing 4A. Pulled the back seat up but it seemed loudest when I was listening in the OSR arch. Pulled the connections off the fuel filter and it took about 1/3 of a filter's worth of diesel before it was full. I then cracked the injectors (each bank seperately) and diesel was coming out when i turned it over. But wouldn't start? Should the diesel come out if the system was immobilised? Also the lift pump didn't pump any fuel out of the filter unions when they were off as Adamss24 had mentioned. Bit odd it's got a pump tho being a 1999 car.
    I got an OBD /USb today and with 409.1 I got the following message
    Address 01: Engine
    Controller: 4B0 907 401 P2
    Component: 2.5l/4VT EDC 0000AG D60
    Coding: 01001
    Shop #: WSC 02325
    1 Fault Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 - -
    Readiness: N/A
    BUT i cleared the code and then tried to restart it several times and no code was then reported.
    Any ideas folks?
    Phil
    ps now disenchanted with 4300rpm at 70 in 5th in my 205!
    Last edited by philfingers; 26-03-2009 at 08:53 AM. Reason: changed to didn't pump fuel out
  2. Re: A6 2.5 TDi AFB Won't Start
    #12
    Jun 2006
    UK, Mids
    I think there is an anti-shudder valve which closed when you switch off the ignition to stop the car shuddering as the engine stops. It makes it stop dead. This may still be shut stopping the car from starting.I think it is at the back right near the turbo.
    Audi A8 - 2015 - 3.0TDI
  3. Re: A6 2.5 TDi AFB Won't Start
    #13
    Mar 2009
    Close to where the fuel pipes run from the filter there are three sender type devices. One with a white rubber boot and spade, one with a JPT (Junior Power timer) connector and a third spade.
    Will take a look tonight for the valve you're talkign about. I guess it will be somewhere in the fuel line,
    Phil
  4. Re: A6 2.5 TDi AFB Won't Start
    #14
    Jun 2006
    UK, Mids
    Quote Originally Posted by philfingers View Post
    Phil
    It closes off the air intake. I have only read about it, not seen it to be honest.
  5. Re: A6 2.5 TDi AFB Won't Start
    #15
    Mar 2009
    the more I think about this it's odd that the fuel filter was only ~2/3rds full of fuel. how can this happen? the takeoff's/ unions are at the top of the filter, there's not even a drain at the bottom of the filter for water removal and there's no visible leaks.... . oh and the car is the right way up!
    Couple of Qs
    1) So if this a definate that the lfit pump will not/ should not pump fuel to the filter. Ie if I run the pump with the unions off the filter I shouldn't see any fuel coming out?
    2) if the small pipes (returns?) between the injectors are weak/perished will these allow the fuel to run back to the tank?
    I have an old facet petrol pump for carbs at home. Going to run that from a tank of diesel into the filter and see if that will sort the problem. Runs at around 6psi from memory so shouldn't damage anything should it?????
    Since I reset the fault code for the immobiliser it hasn't come back on (tried to restart 3-4 times) so i guess it's a code that was there for a while and I have no present fault.
    Phil
  6. Re: A6 2.5 TDi AFB Won't Start
    #16
    Jun 2007
    So you have established you do have a liter pump as you can hear it priming but no fuel at engine. I suggest your problem may be in the tank, there are several small pipes associated to the pump and one may have come off or has split. I Suuest you remove the rear seat and remove the tank pump inspection cover and disconnet the output pipe and attach a pipe into a container and prime the pump, if no fuel comes out then you have your problem. If you PM me your email address and a remider of the year and model I send you all the information you will need. Regards Peter
  7. Re: A6 2.5 TDi AFB Won't Start
    #17
    Mar 2009
    this is all a bit odd. So far as I could see there isn't any form of inspection cover/hatch under the base of the rear seat. Something is definately running under there tho and pulls 4A! PM sent, thanks for your help so far!
    Phil
  8. Re: A6 2.5 TDi AFB Won't Start
    #18
    Jun 2007
    They all have a t least one. Remove the seat and the backrest, lift the sound felt on the drivers side and there is a cover. I sent you a drawing ref 60001. Regards Peter
  9. Re: A6 2.5 TDi AFB Won't Start
    #19
    Mar 2009
    It started! I checked that there was voltage present on the fuse for the pump when I turned the ign on and also on cranking and there was. With a fully charged battery having filled the fuel filter 2 days ago it started after spinning it over for about 15 secs. There were lots of air bubbles in the clear fuel tube.
    Tomorrow I will try and get a look at the lift pump. The return pipes from the injectors are in poor shape so I intend to do those at the same time as do all the belts tomorrow, with water pump and thermostat.
    Must be down to a leak in the pipe work I guess. Tho it never drops any oil or fuel
  10. Re: A6 2.5 TDi AFB Won't Start
    #20
    Jun 2007
    Do you have access to a manual for changing the belts, special to type tools, and locking tools. If not do not start this job. Regards Peter
  1. Please Help A3 won't start!
    By sportbackgirl in forum Audi A3 - Archive Topics
    Last Post: 26-11-2008, 11:46 PM
  2. Please Help ......my car won't start
    By thecoolalhambra in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2008, 08:40 AM
  3. Please Help gt tdi 115 will not start
    By DEL_BOI in forum Golf MK4 - 1999 - 2004
    Last Post: 14-08-2008, 10:35 PM
  4. why cant you just start it up and go
    By paulas80 in forum 80 - 90
    Last Post: 25-02-2008, 09:19 PM
  5. S4 start up
    By aidanjaye in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-05-2007, 06:59 PM
