Thread: VW POLO Late 2005 Blower Speed problem
Results 1 to 10 of 16
  1. VW POLO Late 2005 Blower Speed problem
    Mar 2009
    My Oct 2005 VW Polo blower fan only works on Speed 4 ,
    Reading previous Threads , Looks like the resisitor pack has gone ,
    Took out the glove box to find only 2 pin connector straight to the Fan Motor
    No sign of a Resistor Pack?
    Anyone tell me location of where the resistor pack is mounted , so i can check out
  2. Re: VW POLO Late 2005 Blower Speed problem
    Jul 2008
    Had same problem a week or two back.
    OK, once you've removed the glove-box and tugged the soundproofing out of the way you can see the blower motor. The Resistor pack actually sticks into the top of the ducting. If you look just to the top-right of the blower, you can see the plug and wiring on top. Squeeze the tabs front and back to release the wiring connector from the resistor then about half a turn anticlockwise and it just pops out. It's a little tight for space but not too bad.
  3. Re: VW POLO Late 2005 Blower Speed problem
    Mar 2009
    Quote Originally Posted by PoloTDI View Post
    Excellent TDI
    Got it
    how much did it cost for a replacement , did you get the part from volkswagen
  4. Re: VW POLO Late 2005 Blower Speed problem
    Jul 2008
    I googled it and had a look on E-bay and couldn't find one so, yes needed to get it from Vdub, plus it wasn't a stock item so the ordered it and I got it next day. £34 + Vat if I remember correctly.
  5. Re: VW POLO Late 2005 Blower Speed problem
    Mar 2009
    Got one from VW Yesterday and fitted all oK Now
    Cost 33 Pounds In vat
  6. Re: VW POLO Late 2005 Blower Speed problem
    Jul 2008
    Cool, glad you're sorted..
  7. Re: VW POLO Late 2005 Blower Speed problem
    Dec 2012
    Newcastle upon Tyne
    I'm struggling with this part, just can't release the wiring connector from the resistor!! Should I be wearing gloves, would that make it any easier? Any tips from anyone would be greatly appreciated. Thanks in anticipation.
  8. Re: VW POLO Late 2005 Blower Speed problem
    Jul 2008
    Quote Originally Posted by neilrich3 View Post
    From what I remember it's just a matter of making sure you have pushed the retaining clips in before you try and pull it out. I just shone a torch up beyond the motor assembly so I could see the connector first. So I knew which bits to press..
    I'd go and have a look for you but my Tdi has been replaced by a 1.2Tsi now
  9. Re: VW POLO Late 2005 Blower Speed problem
    Dec 2012
    Newcastle upon Tyne
    Thanks for the speedy response, I can feel the tabs and can squeeze them, but there's just no give. I'll try again tomorrow in the daylight, thanks again for your reply.
  10. Re: VW POLO Late 2005 Blower Speed problem
    Jul 2008
    Here ya go, found these on YouTube. Might help..
    Replace VW Polo Ballast Resistor - YouTube
    How to Change Heater Resistor on Vw Polo (Model 9n) 2002 - YouTube
  1. 2005 Polo 1.4 TDi Charging problem
    By Corsadad in forum Polo - Derby - Lupo - Fox
    Last Post: 08-06-2021, 06:45 AM
  2. Question 02 Polo TDi Heater blower problems
    By PoloTDI in forum Polo - Derby - Lupo - Fox
    Last Post: 30-01-2009, 06:04 PM
  3. Late 2005 (new model) Polo E
    By aaronon in forum Polo - Derby - Lupo - Fox
    Last Post: 13-11-2008, 08:13 PM
  4. Windscreen defrost blower speed
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-02-2008, 11:15 AM
  5. Polo Mk2 Heater speed problem
    By JKnaggs in forum Polo - Derby - Lupo - Fox
    Last Post: 20-11-2007, 08:52 PM
