Thread: b6 cab roof code 02000
  1. b6 cab roof code 02000
    Dec 2007
    1st day of sun roof fails geting code 02000
    02000 - Switch Position: Implausible Signal
    Possible Symptoms
    • Automatic Roof not working
    Possible Causes
    • Automatic Roof Switch Positions implausible
      • Micro Switch faulty
    Possible Solutions
    • Check Micro Switches
      • Check Measuring Value Blocks (MVB)
    Special Notes
  2. Re: b6 cab roof code 02000
    Feb 2009
    Hi Bez,
    Still having problems with mine but today I was messing with it and disconnected the little connector on the drivers side in the roof mechanism (open roof manually and look behind the right hand rear seat into the workings and you will see a cable going into a round micro switch (is a potentiometer) that moves with the the roof.
    I removed mine and twiddled it abit and the code disappeared
    Let me know if you need more info/pic
    Also, you said before you reset your roof, how did you do this?
    Thanks,
    Walter.
  3. Re: b6 cab roof code 02000
    Dec 2007
    mines workin again below is how to reset the micro switch
    Channel 01: Reset
    Prerequisites:
    • Automatic Roof closed
    • Measuring Value Blocks (MVB) OK
    To reset the switch positions, save a new value of 1.
  4. Re: b6 cab roof code 02000
    Feb 2009
    Good to hear its working again,
    What is meant by MVB ok?
    I can see the measuring blocks in vagcom but they show values that seem to be to do with the switch positions.
    Btw, does one have to log into the roof module to reset it and how many measuring block are there?
    also do you know where the "top valve switch" is?
    Any help would be appreciated,
    Walter
  5. Re: b6 cab roof code 02000
    May 2007
    knee deep in clunge
    14 Post(s)
    rest the roof by opening with the emergency release
    carry out a full open and close procedure with a second person to help you lift and lower the roof then try the roof as normal
  6. Re: b6 cab roof code 02000
    Feb 2009
    Hi Bez,
    Got mine working but came across this, might be of interest to you, either way it helps explain how the roof works,
    http://www.justanswer.com/uploads/ca...ertableTop.pdf
    Walter.
  1. A4 Cabriolet Roof Trouble Code 01996
    By Paul Dobson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-03-2009, 02:13 AM
  2. Question Roof Box
    By Richmix in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-11-2008, 02:25 PM
  3. cab roof
    By davidfbmw in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-03-2008, 02:56 PM
  4. Sun roof
    By Ewster in forum Golf MK4 - 1999 - 2004
    Last Post: 04-02-2008, 11:52 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
