Thread: rcd 300 cd won't eject
  1. rcd 300 cd won't eject
    Feb 2009
    I have a rcd 300 fitted to my golf but can't get the cd to eject.
    Can anyone help me out.
    Many thanks
  2. Re: rcd 300 cd won't eject
    May 2009
    dawlishengland
    I Have the same problem with mine.
    The CD keeps chattering inside & is trying to come out.
    I'm going to take out the stereo today (carefully) & try to remove the dodgy CD.
    I'll let you know how I get on.
  3. Re: rcd 300 cd won't eject
    May 2009
    dawlishengland
    Just done it, piece of p***.
    Actually I'd put 2 cd's in at once. Stupid me.
    OK, this is what I did.
    Above the radio are two plastic face plates, one is the credit card holder & the other is the airbag "off" warning indicator. Using a small flat ended screwdriver (I used a metal kitchen spatula) flip out these plastic covers, unclip the airbag multi-plug & underneath are two torx headed screws. Undo the screws & CAREFULLY unclip the face plate around the radio (which also includes both airvents). Leaving the hazzard light multiplug connected place the entire face plate ontop of your dashboard. Then just 4 more torx screws holding in the radio & it's out !!. I then took out 2 tiny torx bolts on the side of the unit (this holds on the top plate), plugged the radio back in to power it up & helped out the cd. Works perfectly.
    Hope this helps friend.
    Andy
  4. Re: rcd 300 cd won't eject
    Jul 2009
    newbury
    I did the same, took it apart last night, now airbag won't go off!!
  5. Re: rcd 300 cd won't eject
    Coventry, United Kingdom
    Quote Originally Posted by james1969 View Post
    Andy
    Hey Andy
    Did you actually open up the stereo head unit to get the CD's out? I've got the same problem, am fairly confident in removing bits of trim, wires and torx bolts, but haven't opened up a stereo unit before.
    Did you have to take any special precautions when opening up the head unit?
    Ta
  6. Re: rcd 300 cd won't eject
    daclyn Guest
    We put a CD in upside down and had to GRAB it as it kept coming out and going in very quickly.
    Hope this helps.
  1. Please Help My A3 Wont Eject Cd
    By Janus99 in forum In Car Entertainment
    Last Post: 26-11-2008, 10:43 PM
  2. Navigation DVD will not eject
    By Sharoedge in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-11-2008, 10:37 PM
  3. Brand new member with a CD eject problem
    By L1ghty in forum Golf MK5 - 2004 - 2009
    Last Post: 19-12-2007, 09:42 PM
  4. cannot eject DVD
    By Potsy in forum Audi A4 - Archive Topics
    Last Post: 21-02-2007, 02:12 PM
  5. why does the cd eject when i turn off ignition
    By mark r wilson in forum Passat - Archive Topics
    Last Post: 25-01-2007, 01:45 PM
