Thread: Front sidelight bulb change A4 B7 / how??
Results 1 to 8 of 8
  1. Front sidelight bulb change A4 B7 / how??
    Mar 2009
    Stockholm
    At the risk of appearing stupid, how the hell do you change the front sidelight bulb on a B7?
    I have opened up the round access hole on the back of the headlamp unit and I can fiddle with the wires that lead to the sidelight, but there is no way to get hold of the lamp holder. I cannot get my hand in there.
    Someone said it's just a pull push fit, so I can tug on the wires and it will come out. Great, but how the hell do I then get it back in.
    Has anyone found a simple way or tool to do this?
    BTW I don't have huge hands before anyone asks!
  2. Re: Front sidelight bulb change A4 B7 / how??
    Aug 2008
    i had this problem i gave one a hard tug and it came out, on the otherside the wire came out (oops).
    i got that out with a long nose plyers that i angled in from the side . The bulbs pop back into place .
    2.0 T FSI quattro S-Line
  3. Re: Front sidelight bulb change A4 B7 / how??
    Mar 2009
    Stockholm
    Thanks - I'll give it a go at the weekend.
    Can you remember if the bulb was a blade fitting or old fashioned bayonet fitting type?
  4. Re: Front sidelight bulb change A4 B7 / how??
    Aug 2008
    i believe it was a blade
  5. Re: Front sidelight bulb change A4 B7 / how??
    Jun 2008
    Marmitehampton
    As stated - give them a good tug...
    To aid refitting, turn them on... Then look from the front, push and bingo!
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  6. Re: Front sidelight bulb change A4 B7 / how??
    Mar 2009
    Stockholm
    Great tip Flakmunky, make it much easier to locate the sidelight bulbs. So simple
    Quattromaxx, it was a blade type fitting, now have XXX super whites in.
    This now completes my foward lighting mods. Changed day time running lights (standard in Sweden) to 27 SMT led's which look awesome, plus added strip of 9 super white leds to each horizontal fin next to the fog lights. They make the B7 look so much newer and not boyracer!. If anyone's interested I can post photo's and explain how I wired with resistors and heat sinks etc.
    Only if you're interested. Well worth the time and money, but only if you have Xenons though.
    2007 A4 2.0 TFSI Quattro S-Line Avant
    auto with s/w paddle shift
  7. Re: Front sidelight bulb change A4 B7 / how??
    Jun 2008
    Marmitehampton
    I can't take the credit for that tip... KodKod.84 suggested this tip in this thread.
  8. Re: Front sidelight bulb change A4 B7 / how??
    Norwich
    Yep no worries- we are all here to help
  1. Replacing sidelight bulb on A6
    By PapaG in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-05-2010, 04:08 PM
  2. Sidelight bulb swap
    By JayB5UK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-03-2008, 06:57 PM
  3. sidelight bulb renewel
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2007, 09:12 PM
  4. A4 Sidelight Bulb
    By shabs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-02-2007, 06:22 PM
  5. Sidelight Bulb
    By Paul JP in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-04-2006, 09:51 PM
