Thread: A4 2007 built in Microphone
  1. A4 2007 built in Microphone
    Feb 2009
    I'm looking to integrate my Nokia Bluetooth car kit to my 2007 A4 Avant.
    It's already rigged up using it's own speaker and mic, but I want to improve.
    Adding to the Car audio system seems fine (Concert with Bose Amp) - I've all the info I need for that.
    The bit I need help with is the microphone.
    I removed the headliner lamp area and think I've found a built in mic - Question is ..
    Can i use this with the Nokia kit (CK-7W) ?
    and if so ....
    Where can I pick up the cables in the bulkhead area ?
    If not, I need to run the cable up to here for the Nokia mic - what's the easiest/neatest way to get there up the A pillar ?
    Many thanks in advance
    Stu
  2. Re: A4 2007 built in Microphone
    Jun 2008
    Marmitehampton
    That mic is for the Bose system and so you shouldn't use it...
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  3. Re: A4 2007 built in Microphone
    Feb 2009
    Quote Originally Posted by Flakmunky View Post
    And used for setting up the sound ? Hence no use ?
    Cheers, Stu
  4. Re: A4 2007 built in Microphone
    Jun 2008
    Marmitehampton
    Sorry, I was in a rush when I posted...
    It is used by the Bose system to monitor cabin noise and adjust the output to counteract noise. So yes, it is used by the sound system and is a specialist mic...
    The Audi mic is a quite expensive at around £65 but does fit in the overhead cluster. I ran a wire up to the cluster and just tucked it between the windscreen and the A-pillar. No need to remove trim and it hasn't worked its way loose...
    EDIT: Have a look at the Parrot MultiCan which is a module that interfaces with the steering wheel controls to enable them to control the unit... I was looking at this solution but then got a full Audi system for the same price from Fleabay...
  5. Re: A4 2007 built in Microphone
    Feb 2009
    It is used by the Bose system to monitor cabin noise and adjust the output to counteract noise. So yes, it is used by the sound system and is a specialist mic........
    Thanks for the info.
    I already had a Nokia Bluetooth kit, so used that to mute the radio. Mounted the Mic as you suggested with ease!
    Whilst I was on, also installed a XCarlink USB/SD MP3 player - integrates to the Concert system as though it's a multi CD changer - all working fine.
  1. It's built
    By gregpawley in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-02-2009, 09:20 PM
  2. HF microphone
    By Idän Jari in forum Golf Plus
    Last Post: 21-09-2008, 11:28 AM
  3. How to increase microphone volume on audi bluetooth kit
    By amped2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-07-2008, 08:23 AM
  4. Where was my car built?
    By barryG in forum Chat - Anything with wheels
    Last Post: 15-03-2008, 05:47 PM
  5. Watch an Eos being built
    By jonthebarber in forum Eos
    Last Post: 27-08-2007, 10:00 PM
