Thread: vw wheels on a vauxhall
  1. vw wheels on a vauxhall
    Dec 2008
    ive got a vw caddy mk1 and a corsa conbo van and i just wondered if the wheels are a straght swap as i need to swap the tyres around.
  2. Re: vw wheels on a vauxhall
    Caddy 4x100 35-38 mm offset centre bore 57.1 mm
    V/hall 4x100 38-49 mm offset centre bore 56.6 mm
    The vw wheels will sit wider on the v/hall and you might run into balancing problems with the centre bore being slightly different.
    The other way the v/hall rims will not fit the vw centre bore and the offset is likely to cause problems with the steering and clearance issues
  3. Re: vw wheels on a vauxhall
    Nov 2008
    Cheshire
    you might just get away with the offset, i had et35's on a corsa as it was ok
  4. Thumbs up Re: vw wheels on a vauxhall
    Mar 2006
    county durham (north east uk)
    Quote Originally Posted by Scott9824 View Post
    me too, i had 205-40-17 7x17" 4x100 et35 on my mk3 cavalier & put them straight onto my vw vento 4 stud with no probs at all,
  1. Free from Vauxhall (at last!)
    By audiix in forum New Member Introductions
    Last Post: 13-02-2009, 12:09 AM
  2. Ford and Vauxhall increase prices
    By ashadam in forum Chat - Completely Off Topic
    Last Post: 04-02-2009, 12:55 AM
  3. Question BBS wheels
    By v6dub in forum Golf MK4 - 1999 - 2004
    Last Post: 16-01-2009, 02:55 PM
  4. wheels
    By benson1 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-10-2008, 04:11 PM
  5. S4 wheels
    By S4SIMON in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-08-2007, 12:50 PM
