Thread: Is it possible to replace a ABS Control Unit & Pump?
  1. Is it possible to replace a ABS Control Unit & Pump?
    I've been told that I need a new ABS Control Unit & pump for my 2002 VW 1.9 Golf GT TDI 130 BHP. I've been quoted over a grand for a new one, so I'm looking at getting a 2nd hand one.
    The only thing is, I'm being told that it's not possible to fit a 2nd hand or reconditioned ABS Control Unit as there are "coding issues". Does anyone know if this is true? If not, is there anything else that I need to take into account?
    Thanks a lot.
  2. Re: Is it possible to replace a ABS Control Unit & Pump?
    Jan 2009
    towcester northants
    you may be lucky to get one with same code
    you will need diag machine to code/reset memory but they are reletively easy to fit if you have a pressure bleeder
  3. Re: Is it possible to replace a ABS Control Unit & Pump?
    Jan 2009
    yes, i've just replaced mine on my mk4 1.8t, all i needed to do was clear the fault code once the pump was fitted. My pump was a reconditioned one and i've had no problems, as long as it's same part numbers as your old one you should be ok. Try www.autotekelectronics.co.uk this is were i got mine which cost me a total of £100 with posatge which was a far cry from some of the prices i was qouted. Hope this helps good luck. Oh and make sure you've checked all the connections and fuses first, there's 3 on top of the battery that are common for going, could save you money..
  4. Re: Is it possible to replace a ABS Control Unit & Pump?
    Aug 2008
    Hereford
    Quote Originally Posted by Tony1010 View Post
    Thanks a lot.
    Reminds me of mine..1st you MUST get a vag fault code check done, and let us know the results,...but the easiest and cheapest check you can do is the 3 green fuses on top of the battery under the little black plastic flap, they control the ABS module, they tend to corrode limiting the power the module receives giving you a 'rogue' abs fault, do it with the ignition off, replace them, then drive approx 100 yards, at least 20mph, see if its cured
    HTH
  1. ABS Control Unit & pump on the blink - Help!!!
    By Tony1010 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-02-2009, 12:01 PM
  2. Please Help VW Golf MK4 - How do I replace the cigarette lighter unit?
    By bigpidge in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2009, 06:05 PM
  3. Replace H12 Alarm Unit Backup Battery
    By richard@thebrae in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2008, 10:35 AM
  4. Locating Central control unit and window control unit
    By AdamPhillips88 in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 08:59 PM
  5. Replace standard radio unit
    By alpappy in forum Eos
    Last Post: 24-02-2007, 08:39 PM
