Thread: VAG Tools
  1. VAG Tools
    Mar 2008
    I need to tighten a steering rack and the procedure requires the use of VAG Special Tool 3315 (A kit of ~10 tools). Anyone any ideas where I could get hold of one (either to borrow/rent) OR any independent who might have this kit in his workshop (in SE England)?
    I've tried my local VW Garages and they can't help... if they can't where do I go?
    HoG
  2. Re: VAG Tools
    Jan 2009
    towcester northants
    what are you trying to tighten?
    17mm socket for pinion
    32mm spanner for tie rods
    tie rods non adjustable
  3. Re: VAG Tools
    Mar 2008
    According to the workshop manuals you can tighten the rack itself... Attached is a photo of the actual fitting....
    HoG
  4. Re: VAG Tools
    Jan 2009
    towcester northants
    i see its a different type to usual
    measure the across the flats a go to your local halfords to see if they have a allen key or can get one
    tweak up small amounts at a time to adjust but check when both wheels are suspended and turn wheel from side to side checking for tight spots
  5. Re: VAG Tools
    Mar 2008
    Thanks for your help - but alas not so simple....
    The piping partly obscures the fitting so you can't get an Allen key into it - I could get into it with a nut and bolt cut down but I can't find one the correct size!! (21mm)
    To add insult to injury, the adjustment is held in place with a locking ring around the outside (~40mm) - something like a crows foot spanner might get round it to also avoid the hydraulics (but at 40mm such a spanner is v. expensive!)
    The VAG Tool (#3315) is a kit of ~10 different specials that get over these problems easily (well relatively)!
    The whole job would take less than 30mins if I could find this kit - without it its a big job!
    Hmmmmm...
  6. Re: VAG Tools
    Jan 2009
    towcester northants
    ive never used this tool sorry cant be of any help
    would a big set of adjustable spanners do?
  7. Re: VAG Tools
    Mar 2008
    There is just no access to get any thing in there!
    Thanks for trying - unfortunately no one seems to have ever seen this tool.
  1. Tools for Cambelt Change
    By hidnmine in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-10-2008, 06:04 PM
  2. 52 a6 2.5 cam belt kit tools
    By mpq123 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-08-2008, 10:10 PM
  3. Gearbox Special Tools
    By sihalliday in forum Golf MK4 - 1999 - 2004
    Last Post: 03-01-2008, 09:48 PM
  4. VAG tools
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 10-10-2007, 02:48 PM
  5. Tools
    By audihenny in forum A8 - S8 - V8
    Last Post: 12-06-2007, 03:48 PM
