Thread: Need to locate these airbag sensor locations
Results 1 to 10 of 15
  1. Need to locate these airbag sensor locations
    Canada
    Hi all I have and error list from my car concerning the airbag sensors can anyone tell me where they live, don't want to remove trim in a random way
    I need to clean the connections first as the car did have a big bath If there gone I will replace them.
    Thanks in advance
    Rob
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
    Component: 38 AIRBAG VW8 018 2200
    Revision: 02018000 Serial number: 0038MD06SWZI
    Coding: 0013112
    Shop #: WSC 01269 785 00200
    7 Faults Found:
    00003 - Control Module
    014 - Defective - MIL ON
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
    008 - Implausible Signal - Intermittent - MIL ON
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
    01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257)
    01638 - Crash-Sensor for Side Airbag; Rear Drivers Side (G256)
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
    010 - Open or Short to Plus - Intermittent - MIL ON
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent - MIL ON
  2. Re: Need to locate these airbag sensor locations
    Coventry
    Quote Originally Posted by onzarob View Post
    Yes.
  3. Re: Need to locate these airbag sensor locations
    Coventry
    email sent as before
  4. Re: Need to locate these airbag sensor locations
    Canada
    Quote Originally Posted by golfmk5gttdi View Post
    My brain is a little slow today, I have now gone and bought a Haynes Manual.....don't know why I didn't before
    Anyone need a maunals for and A4, Citreon Xsara, MG Midget or Golf MK1...the deleted one covering the cabriolet
    I'm running out of shelf space
  5. Re: Need to locate these airbag sensor locations
    Canada
    I have found the source of my problem a very wet controller. Thanks ben for the help
    Just for info the airbag controller is easily removed without following the haynes manual, i remove my whole console to find i just need to remove the 2 pieces of plastic either side, 2 screws!!!
  6. Re: Need to locate these airbag sensor locations
    Canada
    Well looking into the erro codes and the controller itself, I'm hazarding that it maybe toasted. water and electrics don't mix!!!
    This leads me to my next question, when I get a replacement controller, are there any specific moves i need to do, or just plug in, connect battery and go???
  7. Re: Need to locate these airbag sensor locations
    Hi It will need to be coded, you have the coding from the old unit 0013112 this will probably save you a lot of hassle,otherwise you will need to search (guided functions) regarding the index code on the unit.
  8. Re: Need to locate these airbag sensor locations
    Canada
    Quote Originally Posted by kenney View Post
    I get the coding bit, is that from the controller itself, if so that means the controller was successfully interrogated. What I'm thinking now that the controller is dried out, do you think it will be working?
  9. Re: Need to locate these airbag sensor locations
    Yes there is a good possiblity,if you are lucky.They cost a small fortune,but there are firms that can repair them for a lot less than what they cost.
  10. Re: Need to locate these airbag sensor locations
    Canada
    I will give it a try, even just to double check the adaption code, I assume this is for the number of airbag. ie seat, steering wheel, curtain etc.
    What is the guided functions...is that in VCDS?
  1. Please Help Please, please help.. can't locate coolant temp sensor TDI 150 2002
    By ax_box in forum Golf MK4 - 1999 - 2004
    Last Post: 20-09-2008, 11:13 AM
  2. Seats - Airbag sensor (Subframe with Airbag Resistor)
    By greg_gorr in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-08-2008, 08:43 AM
  3. Airbag Sensor on 2000 Passat..
    By Jigs in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2007, 02:09 AM
  4. airbag sensor
    By kharva007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-05-2007, 01:10 AM
  5. Airbag Sensor location ???
    By MrSpiffy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2007, 07:25 PM
