Thread: tdi coolant
Results 1 to 10 of 17
  1. tdi coolant
    Stafford, Midlands
    my coolant light came on last night, big flashy red thing, anyway, rather than cadging a few litres off the local vw place for 8 quid a litre, is there any off the shelf stuff that'll go straight in, like halfords or anything, which one do they do for the tdi etc, thanks in advance, need it today so mail order isnt really an option.
    Subaru broken, sold, Silver Seat Leon Cupra 180 '02' no cupra badge?
  2. Re: tdi coolant
    london/ UK
    Try ECP, they do g12 antifreeze for 15 quid incl.VAT for 5L. Halfords do it as well but its dearer at 20 quid a can. If you go to halfords look for the concentrated one as they do ready mixed one as well and its not cheaper. Look for the dark blue bottle with pink coolant inside ! Check first what coolant you have in the bootle as its not recomended to mix the green with pink coolants !
  3. Re: tdi coolant
    Stafford, Midlands
    have vw pink stuff at the moment, not meant to be anything else i have read? its 30 miles to my vw dealer, may just ring my vw specialist an get them to sell me some, its only 2 miles away and it'll be the same stuff.
  4. Re: tdi coolant
    Stafford, Midlands
    i had a good look under the bonnet and it turns out the pipe that goes to the heater matrix is all crudded up at the end and leaking because of this, no holes in the pipes themselves, took it to the garage who had a look and he suggested taking pipe off the fitting, taking the fitting off and giving it a clean up, then refitting the pipe, sounded logical, think its only lost enough to give warning light, but thats too much, i got 2 litres of g12 from the vw guys at the garage and they charged me a tenner, bargain then booked it in for rear pads and discs
  5. Re: tdi coolant
    Oct 2005
    sligo ireland
    looks as the pipe needs to be tied back so as not to give future problems
    pauk
  6. Question Re: tdi coolant
    Mar 2007
    U-96
    Hope that I'm not splitting hairs here;
    Quote Originally Posted by adamss24 View Post
    Hi Adams.,
    1) I believe the ECP generic coolant is the "CarPlan Premium Red Anti-freeze". It is red (well the name says it all ) and states 5 years extended life, costs £14.99 for 5L and claims to conform to VW G12 standard (ECP part number 523770241). It is Ethylene Glycol based but contains Organic Acid Technology and Ethanediol.
    2) GSF also sell a Febi manufactured Purple coolant that costs £4.00 for 1.5L (GSF part number: 98074), with the correct VAG G12 part number (G.012.A8F.A1).
    3) I think that VAG's own Purple G12++ higher grade coolant costs £8.18 for 1.5L (VAG part number: G.012.A8G.M1).
    All coolants can be mixed 50:50 with (distilled/deionised) water for -36 deg. C protection.
    Personally, based on price and the manufacturer I'd opt for (2), the Febi coolant.
    Two quick questions;
    1) Does unused coolant (either sealed or opened) have an expiry date ?
    2) Can anyone please recommend a retail supplier of Grade 10.9 (Automotive) Bolts ?
  7. Re: tdi coolant
    london/ UK
    Quote Originally Posted by tornadored7 View Post
    Hi Adams.,
    Hi, as you allready said, you get what you pay for. As you mentioned, red/pink/orange antifreeze is G12 spec and should NOT be mixed with the green/blue G11 antifreeze. The g12+ wich the dealer sells is purple in colour and it WILL mix safely with G11 and G12 coolants... I have been using Halfords and ECP stuff for a few years now and its perfectly adequate.. I do not think open coolant has a shelf life while its open as long as it does not get contaminated it should be ok.
  8. Re: tdi coolant
    Stafford, Midlands
    Quote Originally Posted by paulthefox View Post
    pauk
    concering coolant, i go by what the garage usually fits in mine, which is luminous orangey pinky colour, sitting in a coke bottle in the boot, my lads eyes lit up when he saw it, thinking it was a new type of coke
    yeah will check that out tommorow too, had only noticed it when i looked at photo so dont know what it is till i have a fertle around, will probably gaffer it till i get a replacement length of silicone to sort it.
  9. Re: tdi coolant
    Mar 2007
    U-96
    Thanks for the replies Gents.
    However, I am still trying to understand what the difference in expiry date between opened and unused coolant and coolant in a car is ? i.e. What makes coolant in a car cooling system expire, whereas bottled coolant doesn't ?
    Is it the thermal stress endured within a car's cooling system ?
    BTW Stuey,
    Safety first: I'm not trying to teach you to suck eggs, but if kids see a coke bottle containing something as toxic as coolant ...
  10. Re: tdi coolant
    May 2008
    Leeds, W Yorks
    No, the coolant has an anticorrosive action which is 'used up' over time and so should be changed periodically to maintain the protection. I dont't believe the anti-freeze properties are affected by age.
  1. Rapid Coolant Loss and Coolant Alert
    By BigSMan in forum Golf MK4 - 1999 - 2004
    Last Post: 21-01-2009, 11:24 PM
  2. STOP-Check Coolant-Coolant Boiling
    By purch in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-11-2008, 04:12 PM
  3. Coolant light still on after topping up with coolant
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-06-2008, 07:22 PM
  4. Low engine coolant temperature, which coolant to use
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2007, 11:35 AM
  5. s8 low coolant
    By dan256 in forum A8 - S8 - V8
    Last Post: 31-07-2007, 04:12 AM
