Thread: Cabriolet roof warning light
  1. Cabriolet roof warning light
    I'm getting the roof warning light flashing for 10 seconds on startup.
    I've tried disconnecting/reconnecting the battery and I've put a booster on the battery to make sure it's not got a low charge (The battery is less than a year old so should be ok).
    I've also had a look at the roof storage area in the boot which is ok.
    It doesn't affect the roof operation as it will open and close when the warning light is flashing but I'd like to know what it is
    Any ideas would be appreciated - Thanks
  2. Re: Cabriolet roof warning light
    Dec 2008
    Midlands
    If you call Audi (or the Audi RAC) there is a reset procedure for the roof which should remedy this - i had the same thing as well and Audi sent one of their RAC vans out (the car was new) and the engineer went through a procedure of turning certain bolts etc in an order which reset it, then it was job done! Check the manual as well incase the procedure is in there.
    Audi A4 1.8T Quattro Convertible 200+ BHP
    See it here and let me know what you think! : https://www.vwaudiforum.co.uk/forum/s...ad.php?t=81930
    Youtube Channel: www.youtube.com/555senna
  3. Re: Cabriolet roof warning light
    Thanks for the reply - Mines a 2003 so not under warrenty. Can you remember which bolts they looked at?
  4. Re: Cabriolet roof warning light
    129 Post(s)
    1972 Post(s)
    Release the roof with the key stored in the side of the dash with the fuses. The header release is in the centre behind thee mirror and the rear in the top of the rear centre arm rest location. I had one like this the other day and it was the left rear seat belt, the webbing had got caught in the rear deck cover and pushed down into the locking unit, ruined the belt as well.
  5. Re: Cabriolet roof warning light
    Thanks - I've just been looking up how to manually raise and lower the roof to see if that would clear it. It's got to be worth a try
  6. Re: Cabriolet roof warning light
    Dec 2007
    i used vag to reset mine
  7. Re: Cabriolet roof warning light
    Thanks Bez, I've got it booked in for a service at an independant next month and they've got the software to reset it. I'll have a look in to getting Vag as well. Cheers for the help
  1. Cabriolet Roof Problem
    By SRMAJM in forum Golf MK3 - 1993 - 1999
    Last Post: 19-03-2010, 08:47 AM
  2. Attention A4 cabriolet roof
    By kristobelle in forum New Member Introductions
    Last Post: 08-09-2008, 12:20 AM
  3. Remote Cabriolet Roof
    By charlie1302 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2008, 08:49 AM
  4. Please Help golf mk3 cabriolet roof
    By BILLYWHIZZ71 in forum Chat - Anything with wheels
    Last Post: 27-06-2008, 05:32 PM
