Thread: 2005 vw sharan 1.9pd tdi sport burning smell
  1. 2005 vw sharan 1.9pd tdi sport burning smell
    Jan 2009
    i have just bought a 05 plate sharan 1.9 pd tdi sport and there is a slight burning smell from under the car at the back passager door. there is also a noise like a pump running for a couple of mins after the engine is turned off from the same area. can anyone please shed some light on what this is and if it is normal for this to be there as it is still under the warranty from me buying it.
  2. Re: 2005 vw sharan 1.9pd tdi sport burning smell
    Jan 2009
    towcester northants
    this will be your auxillary heater this runs on diesel
    exhaust fumes by passenger door and a sound like a small jet engine?
  3. Re: 2005 vw sharan 1.9pd tdi sport burning smell
    Jul 2006
    scunthorpe
    you've got one that works????????
  4. Re: 2005 vw sharan 1.9pd tdi sport burning smell
    Jan 2009
    Quote Originally Posted by andy e View Post
    i don't know about that. when i put it on to cold air(low) it blows out the back but when i put it on hot air (high or any temp) it stops blowing out air from the back vents.
  5. Re: 2005 vw sharan 1.9pd tdi sport burning smell
    Jan 2009
    could someone with a working aux heater please help clear something up for me.
    when i start the car from cold and on the heater control select hi temp air comes from the front vents there is also air comes from a vent behind the middle row of seats on the back of the wheel arch but i can't get any air to come out of the 5 roof vents ( when hi temp selected). now when i select low temp i can get air out of the front, vent behind the middle row of seats on the back of the wheel arch and the 5 roof vents but as i increase temp you can hear a valve of some kind shut and this then stops the air going to the roof vents. is this normal or do i have a problem.
  6. Re: 2005 vw sharan 1.9pd tdi sport burning smell
    Bristol
    mine still seems to work , 4deg and below and the jet engine kicks in although it doesnt like to go short distances when its on , as when i stop I get masses of smoke from the pipe out the side ,
    Its my james Bond smoke screen
    MK5 Golf TDI 2.0ltr GT Sport in Black
  7. Re: 2005 vw sharan 1.9pd tdi sport burning smell
    Nov 2006
    Quote Originally Posted by shariain uk View Post
    This normal.
    The roof vents only give out cold air NOT heat. So when you turn up the heat the front vents, the one behind the handbrake on the floor and the rear passenger ground floor vent give heat.
    When you turn doen the heat the roof vents allow cold air through.
  1. Please Help Burning Oil / Fuel Smell
    By Uxair in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-01-2009, 12:43 PM
  2. Attention Burning smell
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-05-2008, 02:39 PM
  3. Burning rubber smell
    By wickerman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-05-2007, 11:32 AM
  4. Burning Smell
    By sandman2309 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-03-2007, 04:50 PM
  5. Help - BUrning smell!!!
    By chrisball666 in forum Passat - Archive Topics
    Last Post: 21-12-2006, 09:26 AM
