Thread: Help removing rear number plate screws
Results 1 to 8 of 8
  1. Help removing rear number plate screws
    Hi people !
    Have just received some new plates through the post this morning to replace my old tatty ones, I have removed the front without a problem, However the rear is screwed on , I have removed the plastic caps and have got 2 screw to remove, Do I need to remove the boot lid lineing to remove these screws, if so how do I do it?
  2. Re: Help removing rear number plate screws
    Southern County Softy
    20 Post(s)
    Just unscrew them.
    When I fitted new plates I got Plate surrounds.
    You srew these to the car then the plate mounts in them, no holes and the
    plates hide the screws in the surround.
    http://www.dubmeister.co.uk/
    Have a look at the surrounds.....
    A4 2.5 tdi QS (mapped)
  3. Re: Help removing rear number plate screws
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Quote Originally Posted by kite View Post
    Just unscrew them.
    On that note, mine's got the standard dealer plate surround with the number plate sat in it. It's screwed through with the "hex head" screws that also take a philips screwdriver. The dealer has not screwed one of them in far enough, feels like they have cross threaded the nylon against whatever is in the boot door.
    I've tried undscrewing it but the screw twists (think the whole thing is nylon or something). Anyone got any idea how to get this off and sorted out - as the number plate rattles against the boot door....
    Cheers,
    Dan.
  4. Re: Help removing rear number plate screws
    Quote Originally Posted by danclyon View Post
    Cheers,
    Dan.
    Dan, This is similar to the problem I have , The screws are head less or the head is only accessible by removing the boot lid cover I think?, Mine are also plastic / nylon and dont seem to want to move anywhere when I try to unscrew them with some grippers, I googled around and found someone with a passat who had the same problem, he ended up drilling the plastic screws out, Dont really want to do that.
    Any Ideas anyone ?
  5. Re: Help removing rear number plate screws
    Dec 2007
    Quote Originally Posted by nutter1980 View Post
    Any Ideas anyone ?
    rusted and stripped the head
    mole grips
  6. Re: Help removing rear number plate screws
    Quote Originally Posted by bez101 View Post
    mole grips
    Bez cheers for your input, What do you mean rusted and stripped the head. The screws on the rear plate are plastic?
  7. Re: Help removing rear number plate screws
    Dec 2007
    ops the metal ones usaly rust up plastic ones still mole grip them out if you dont wana do that use the drill
  8. Re: Help removing rear number plate screws
    Sounds good , Grippers and brute force it is then ! think when I apply the adhesive strips I will cover these holes as when washing the cars water will get inside the holes and could cause future rust...
    I know this whole thread is probably a proper noob question , but I wanted to make sure I wouldnt cause other damage by forcing the screws out..
    Cheers Bez..
  1. Attention Rusty Number Plate Screws
    By radox in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2009, 01:44 AM
  2. Rear number plate light replacing
    By MotM in forum Audi A3 - Archive Topics
    Last Post: 08-02-2008, 07:48 PM
  3. rear number plate lamps
    By davidlandy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2008, 12:04 AM
  4. Rear Number plate mountings
    By sherlockuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-01-2008, 02:50 PM
  5. Passat Rear Number Plate
    By keaveney911 in forum Passat - Archive Topics
    Last Post: 17-12-2006, 08:05 PM
