Thread: Flashing light on headlight switch
Results 1 to 8 of 8
  1. Question Flashing light on headlight switch
    Morayshire, Scotland
    I can't work this one out. I have a 56 Reg 2.0 TD A4 and when I start it up, on the headlight switch is a small red illuminated dot at the top of the switch which flashes. It doesn't flash regularly, more like an intermittent connection. When I turn on the side lights or headlights, the red dot goes out and doesn't come on again until I start the engine the next day.
    Anyone know what is going on here
    Ian
  2. Re: Flashing light on headlight switch
    Norwich
    This has been bought up before but with no definite answer, I suggested an automatic light check the car does, any audi techs on here know the answer?
    Is a bit strange though...
  3. Re: Flashing light on headlight switch
    Jan 2009
    Yelverton, Devon
    Me too.
    I have exactly the same sympton. I have only just noticed it and had assumed in was a loose contact somewhere. As long as the lights still work, I was planning to ignore it.
    Ian Vincent
  4. Re: Flashing light on headlight switch
    Jul 2008
    LOL!!! Read a thread about this 2 months ago now and guess what?????????????
    Mine just started doing the same thing the other day...
    May have to stop reading these threads regarding faults....
    AKOYA SILVER B7 A4 2.0 TDI S-LINE BOSE RNS-E/SDS/MFSW VALCONA LEATHER CRUISE ARM REST AMBIENT LIGHT LED INTERIOR LIGHTING DIS S4 MIRROR CAPS BOOT LIP CR SPLITTER 50% TINT
  5. Re: Flashing light on headlight switch
    Dec 2007
    Hi all,
    The little red dot on my light switch has just started to flash, some times it stays on but more often than not it starts to flash once the engine has been running for about a minute, It use to stay on constantly and has just started to flash.
  6. Re: Flashing light on headlight switch
    Aug 2007
    Newport, Wales
    7 Post(s)
    This hasn't happened to me yet, so I can't check...
    Someone with the problem should get their car hooked-up to VAG-Com to get the lighting module / blocks read. Surely there'll be something logged in there?
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  7. Thumbs up Re: Flashing light on headlight switch
    Dec 2007
    Good news,
    Little red dot on my light swith has been sorted, under warranty .
    My local Audi dealer changed the whole light switch cluster, looks great in the dark as it used to be.
    Just thought I would spread the news.
  8. Re: Flashing light on headlight switch
    Aug 2007
    Newport, Wales
    7 Post(s)
    Hmm.. I guess the little red dot should only be lightly illuminated as normal and when something is wrong with the switch's illumination, the red dot flashes to warn you that it's not displaying the headlight & fog-lamp status properly?
    Did Audi confirm what the problem was?
    Al.
    [ Past Audis:
    A6 S-Line 3.0
  1. Headlight Switch
    By squid in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-01-2009, 08:25 PM
  2. headlight switch issue
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-08-2008, 08:10 PM
  3. Headlight Switch Illumination
    By c0l in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2008, 04:41 PM
  4. Polo oil light flashing at switch-on
    By spockley in forum Polo - Derby - Lupo - Fox
    Last Post: 20-04-2007, 09:50 PM
  5. Headlight switch bulbs gone
    By madfella65 in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 08:35 PM
