Thread: dtc 17965,18062,18057
  1. dtc 17965,18062,18057
    Dec 2008
    does anybody know what these codes mean.i bought a vag com with the book of codes,yet these codes are not listed??seat alhambra 1.9tdi 2004.
    what does a/t and srs mean on the scanner..engine and abs i know,but not these 2.any enlightment please.cheers.
  2. Re: dtc 17965,18062,18057
    17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    srs is the abriviation for aitbag systems
  3. Re: dtc 17965,18062,18057
    Dec 2008
    thanks very much. but,how do i check the solenoid valves and where is the charge pressure control unit.
  1. Error Code 17965
    By Sharky_82 in forum VCDS - General Questions
    Last Post: 29-07-2011, 12:22 PM
  2. HELP Trouble codes 18261 and 18057
    By Bluechip in forum Golf MK4 - 1999 - 2004
    Last Post: 12-02-2008, 04:17 PM
  3. error code 17965 on 110 tdi, need a new actuator?
    By tezray in forum Archive posts
    Last Post: 26-10-2007, 04:56 PM
  4. 17965---overboost
    By NinjaXP in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-08-2007, 09:30 PM
  5. 17965
    By Sharky_82 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-01-2007, 04:47 PM
