Thread: Power Steering - Knocking
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Power Steering - Knocking
    May 2006
    South East England
    A6 2002 1.9tdi (130)...
    When stationary and turning the steering wheel to full lock i'm hearing some graunching noises...could be the aux drive belts...its defo not the CV joints as the noise is coming from the engine bay....
    any suggestions on this....i get vibratrion feedback through the steering wheel...
    ta...
  2. Re: Power Steering - Knocking
    london/ UK
    Quote Originally Posted by cronic View Post
    ta...
    alternator one way clutch pulley... Not expensive to buy but needs a special tool to undo. Available from most decent motor factors !
  3. Re: Power Steering - Knocking
    May 2006
    South East England
    cheers for the heads up...i'll go check it...
  4. Re: Power Steering - Knocking
    May 2006
    South East England
    Quote Originally Posted by adamss24 View Post
    hello again....
    car was with my local garage today...he had a look at the pulley on the power steering seemed o.k...the belt did seem a bit worn to him so he replaced it...this hasn't fixed the problrm...he didn't think it was the altenator....but i would like to understand your diagnosis more
    if the altenator clutch pulley was not functioning correctly would this be what is causing the 'slipping' noise at the steering pump pulley...? there is no obvious noise for the pulley next to the altenator....
    i don't suppose you have the electronic manual to illustrate your thoughts....i really need to see which part you are saying is faulty....
    thanks in advance...
  5. Re: Power Steering - Knocking
    Jul 2007
    Cheshire, or my A6
    Cronic, I've had exactly this problem on my A6 and my T5 van, its common across the whole range of TDIs. Its nothing to do with the power steering pump or the belt tension.
    There is a one way clutch bearing built into the alternator pulley. This has to slip on tickover, and it will have seized, hence no slip.
    Look at the poly V belt at the front of the engine. When on tickover at full lock, is this flapping and vibrating? I'm 99% sure it will be, this is the tell-tale sign of the failiure.
    I don't want to say bad things about your local garage, but it sounds like they've totally misdiagnosed the problem.
    I've never seen something so trivial cause such a major problem, and I'm 47 years old!
    Paul
    P.S Sorry to jump in Adamss24!
  6. Re: Power Steering - Knocking
    May 2006
    South East England
    Quote Originally Posted by paul b View Post
    Paul
    O.K so the large pulley directly infront of the altenator is the part in question....please LEARN me for a moment....the pulley actually contains the clutch...?
    we did have a good look together at the belt and couldn't see any noticeable 'flap'....
  7. Re: Power Steering - Knocking
    May 2006
    South East England
    what would the rough price be for a new pulley...?
  8. Re: Power Steering - Knocking
    Jul 2007
    Cheshire, or my A6
    Yes that's the bit you're looking for.
    For a 130bhp AWX its about £60-ish +VAT at Audi.
    I bought mine from Andrew Page Motors for about £46 if I remember correctly.
    Paul
  9. Re: Power Steering - Knocking
    Ive had alternator problems recently, same engine as Paul and if you put a stick in through the alternator into the cooling fan of the alternator and take the tension off the belt the alternator pulley should be jammed if you try to rotate it clockwise but it should turn anticlockwise even with something blocking the cooling fan if the clutch hasnt siezed.
    When i originally got my A6 i started to get grinding noise from the steering, in my case the piece that the tensioner pulley is attached to was bent this caused the tensioner pulley disintegrate.
    Tony
    2016 A6 2.0 TDI S-Line
    1969 Triumph Spitfire (In pieces )
  10. Re: Power Steering - Knocking
    May 2006
    South East England
    o.k i had another look today....belt is defo flapping around...
    whats the best process to get the pulley off....i'm hoping you can do this without removing the front end of the vehicle...as you would do to change the cam belt....
    also...a special tool was mentioned....whats if for exactly...?
    thanks for all the feedback on this....
  1. VW Polo '52 1.4 sport Power Steering Leak Suspension Knocking
    By brigadier in forum Polo - Derby - Lupo - Fox
    Last Post: 03-11-2009, 01:18 PM
  2. Steering Problem - Knocking
    By kopman9 in forum Bora - 1998 - 2005
    Last Post: 23-12-2008, 11:05 PM
  3. Knocking noise when steering
    By kevwall in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2008, 08:24 PM
  4. Steering Knocking
    By Trolley Jack in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2008, 10:01 PM
  5. Steering Knocking
    By MikeA4tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-05-2007, 09:38 AM
