Thread: rear fog lights inop
Results 1 to 10 of 10
  1. rear fog lights inop
    Aug 2007
    My rear fog lights have stopped working.
    The in-dash indicator light, lights up and both the fog light bulbs are good.
    I suspect the relay, does anyone know which one it is?? haynes doesn't really help.
    Thanks in advance
  2. Re: rear fog lights inop
    Jun 2006
    UK, Mids
    I very much doubt there would be a relay for a 21w bulb (there is only one foglight)
    It is most likely the switch or the wiring. You need to find which pin at the back of the switch is for the rear foglight and put 12v down it and see if it comes on. You remove the switch by pushing it in and turning it to sidelights and then pulling out. You could also try swapping it over with someone else's as it only takes 10 seconds.
    Audi A8 - 2015 - 3.0TDI
  3. Re: rear fog lights inop
    Aug 2007
    Thanks for the reply crasher
    If the fog light indicator light in the dash illuminates as it should then I would think the switch is working correctly??
    The Haynes wiring diagram for the fog light circuit shows a relay but not it's position on the relay plate.
    I have aftermarket rear lights fitted so I've 2 rear fogs, they've been fitted for 3 years and no problems up till now
  4. Re: rear fog lights inop
    If the contol light lights,then the switch is ok.There is no fog light relay on factory fitted fog lights
  5. Re: rear fog lights inop
    Aug 2007
    Cheers Kenney, it must be a wiring problem then??
  6. Re: rear fog lights inop
    Jul 2008
    You need to test the light with a multimeter, if no power then test at fuse and work backwards towards the switch.
  7. Re: rear fog lights inop
    Hastings, Great Britain
    Check your fuse box
  8. Re: rear fog lights inop
    Aug 2007
    Quote Originally Posted by SKINNYSEAND View Post
    Check your fuse box
    I've checked the fuses and they're all fine.
  9. Re: rear fog lights inop
    Mar 2007
    Aberdeen
    I had this exact same problem with my old 96 Passat. After checking everything you've checked, I decided to run a new wire all the way from the back of the headlight switch to the rear light clusters and this solved the problem. I can only assume that there must have been a broken/very weak connection somewhere in the original wiring. When I was testing my rear fogs, there was only enough current at the back of the car to illuminate a tiny LED.
  10. Re: rear fog lights inop
    Jul 2008
    Quote Originally Posted by cazyp View Post
    Get one from maplins or similar - very cheap and VERY handy.
  1. 2003 Audi A4-Brake Lights & Rear Lights
    By csheehy35 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2008, 10:12 PM
  2. Rear lights and front lights
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 08-03-2008, 08:27 PM
  3. rear lights inop
    By stuk2000 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-11-2007, 11:46 PM
  4. rear lights inop
    Last Post: 22-11-2007, 07:56 PM
  5. Reverse lights INOP
    By waterman17 in forum New Member Introductions
    Last Post: 08-05-2007, 03:32 PM
