Thread: 1.9Tdi losing coolant but we can't figure out how
Results 1 to 9 of 9
  1. 1.9Tdi losing coolant but we can't figure out how
    Mar 2006
    Basingstoke
    A friend of mine has an R reg 1.9TDI B5 with about 100K on the clock. its losing coolant but only while running. It will alarm every few days (50 mile round trip commute daily) and require topping up.
    The radiator and water pumps have been changed. The water pump had partially failed as a fin was missing. The system has been pressure tested and no leaks found. There are no leaks in the cabin. The heater works normally. There are no pools of water under the car. No signs of dripping or damp smells anywhere. The only odd thing is the downpipe from the coolant reservoir is cold when all others are warm. I checked my 1.8T and the downpipe is about as warm as the main coolant pipes. He's even used radweld and its still losing coolant. Its just disappearing.
    Anyone had this before or could suggest what to look for next?
    thx
    Chris
  2. Re: 1.9Tdi losing coolant but we can't figure out how
    with the engine hot, pop the bonnet and look for any steam vapours rising.
  3. Re: 1.9Tdi losing coolant but we can't figure out how
    london/ UK
    Blown head gasket or a porous head. Diesels are able to run with steam inside pistons so, when you take the head off, it will show where the gasket is blown as the head in that area will be very clean due to the steam.
  4. Re: 1.9Tdi losing coolant but we can't figure out how
    Mar 2006
    Basingstoke
    Thank you both
  5. Re: 1.9Tdi losing coolant but we can't figure out how
    Sep 2008
    I put radweld in the coolant and that worked a treat for me. I had the same problem as you, it will lose coolant every 50 miles.
    Give it a try and see if it works.
  6. Re: 1.9Tdi losing coolant but we can't figure out how
    Gwent
    If you take the top engine cover off, you can check the coolant pipes which bolt to the side of the head, these are plastic, with an O ring seal at the flange. Over time the flange warps and starts leaking.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  7. Re: 1.9Tdi losing coolant but we can't figure out how
    Mar 2006
    Basingstoke
    Quote Originally Posted by gujiguy View Post
    Interesting, how much Radweld did you use?
    Chris
  8. Re: 1.9Tdi losing coolant but we can't figure out how
    Sep 2008
    I bought a little bottle from halfords and poured everything in. I first poured the radweld and then put water in.
    Its been 3 months now and havent had any problem till now.
  9. Re: 1.9Tdi losing coolant but we can't figure out how
    Dec 2007
    8 Post(s)
    Quote Originally Posted by chrisgeary View Post
    Chris
    What Scotty says is 100% These plastic flanges develop
    hairline cracks and the only way is to replace them. New O rings or silicon is a waste of time
  1. touran losing coolant
    By angnlee in forum Touran - Sharan - Caravelle
    Last Post: 17-10-2013, 05:21 PM
  2. Yellow froth, losing coolant
    By FlumpDad in forum Audi A3 - Archive Topics
    Last Post: 16-11-2007, 07:13 PM
  3. '02 reg TDi 130 losing oil and coolant
    By nico in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-05-2007, 10:01 PM
  4. Losing Coolant
    By tonya2 in forum A2
    Last Post: 09-02-2007, 08:03 AM
  5. mk 4 golf 115 tdi losing coolant
    By key-matic in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-11-2006, 09:23 PM
