Thread: can castrol edge 5W-30(longlife oil) be used on a fixed interval service
  1. can castrol edge 5W-30(longlife oil) be used on a fixed interval service
    reason being my service is due and with my low mileage (less than 8K annual) i will be reverting to fixed interval from the variable.
    I still have 6ltr of the castrol edge longlife oil which i want to continue using - expensive stuff i know !
    As far as im aware this is fine to still use
  2. Re: can castrol edge 5W-30(longlife oil) be used on a fixed interval service
    Dec 2008
    Midlands
    I would have thought so because it is specifically made for VW/Audi engines and I believe the manual proposes the use of other oils as ok as long as it has the right qualities - which it has
    Hope this helps and happy new year
    Audi A4 1.8T Quattro Convertible 200+ BHP
    See it here and let me know what you think! : https://www.vwaudiforum.co.uk/forum/s...ad.php?t=81930
    Youtube Channel: www.youtube.com/555senna
  3. Re: can castrol edge 5W-30(longlife oil) be used on a fixed interval service
    Quote Originally Posted by JIGGY C View Post
    Hi Mate - thanks for the quick response - happy new year to you too
    that was my thinking that its an oil specific to audi/vw models
    ill get my mechanic to fill it up
    thanks again
  4. Re: can castrol edge 5W-30(longlife oil) be used on a fixed interval service
    Dec 2008
    East Preston, West Sussex
    Nothing wrong in using this if you have it, but if you are going to used a fixed service interval from now on you may as well use another oil that is just as good but not so expensive, like a different Castrol oil or one from mobil maybe. Just as long as it is the same specifications as stated in your service manual for fixed servicing you will be OK, and quids in!
    John
    2005 A4 B6 Avant 1.9 TDI 130 Sport (6)
  5. Re: can castrol edge 5W-30(longlife oil) be used on a fixed interval service
    May 2007
    The main difference between the long life oil and the normal oil, is that long life is that it is a full synthetic as it needs to retain is viscosity and lubrication properties for a lot longer.
    It's a bit of overkill to use it for normal service distances, but will not do any harm to your engine at all.
    Personnally long life servicing is the worst possible thing to do to an engine, as though the oil retains it's properties the contaminates do not get removed
  6. Re: can castrol edge 5W-30(longlife oil) be used on a fixed interval service
    many thanks lonky - case solved
  7. Re: can castrol edge 5W-30(longlife oil) be used on a fixed interval service
    South Wales
    Its no problem to use better oil at all, i use full synth in my 1.8t and service her on around 6k intervals to prevent sludging problems from
    1.8t conversion : SP51x OUTLAW Turbo @ 25psi : Vmaxx Coils : 6 Speed 'Box : GripForce Stg 3 Clutch : S4 Leather : Facelift Console
    Anyone want to swap my A4 for an A3 or similar?? PM me
    243 bhp @ 6415 / 275 torques @ 3370 Chipped UK Rules
  1. Question Castrol Edge 507 5w 30 Oil Correct Stuff?
    By ax_box in forum Golf MK4 - 1999 - 2004
    Last Post: 06-10-2008, 11:33 PM
  2. Castrol Edge Oil Great Price
    By NascarMike in forum Golf MK5 - 2004 - 2009
    Last Post: 20-07-2008, 12:07 AM
  3. Castrol EDGE 5w-30 going cheap!!!!
    By TimmyTim in forum Chat - Anything with wheels
    Last Post: 13-07-2008, 12:54 PM
  4. service interval castrol long life oil
    By trevor simpson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-06-2008, 01:49 PM
  5. Castrol Edge
    By kimandsally in forum Chat - Anything with wheels
    Last Post: 07-03-2008, 02:11 AM
